Old 06-11-2011   #241
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: GsXtUrBo98's 2G project thread
I got the new master cylinder today and installed it, then bled the clutch/slave and adjusted the clutch. I WORKS! it no longer ingages at the floor! it does however slightly move when the clutch is in and I rev it up but not bad at all.
On a side note I took it for a drive and the steering wheel shakes and when I turn right I hear a grinding noise.... This is just depressing
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 06-11-2011   #242
b00sted_spyder
Your wheels might need to be balanced if the steering wheel shakes.
Old 06-11-2011   #243
GsXtUrBo98
GsXtUrBo98's Avatar
^ yes I thought this but I'm not too sure as to what the grinding noise is..
98 GSX (built)
03 BBY EVO dd
Old 06-12-2011   #244
GsXtUrBo98
GsXtUrBo98's Avatar
After I got my clutch adjusted I reved it up to see if it would drag and my 2 step went off, after this my car only idles at 2200 rpm's... I am going to get the by pass plate ordered tomorrow and put my idle sensor back on.. you guys win
98 GSX (built)
03 BBY EVO dd
Old 06-12-2011   #245
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Amsoil Dealer
Old 06-13-2011   #246
GsXtUrBo98
GsXtUrBo98's Avatar
I ordered some plug wires, vacum block, and the bypass plate for my throttle body today
98 GSX (built)
03 BBY EVO dd
Old 06-14-2011   #247
GsXtUrBo98
GsXtUrBo98's Avatar
Might help to make sure the front 2 tires are tight.... FAIL anyways I snugged them up an were good to go! I got the front bumper trimmed up and installed yesturday and the car is fully driveable now but need to install some more parts. As stated I ordered some more parts but have my head studs to do and rewire of the fuel pump and hook up the bap. Got to have primo weld up my exhaust and make a dump tube aswell. After all is done I need to put insurance on it and get tabs. Finding more ways to spend money on this thing..
98 GSX (built)
03 BBY EVO dd
Old 06-14-2011   #248
95talonracer
Finally Tuned...
Drives: Spyder GSX
Tell us you are recirculating the wg back into the exhaust...
Amsoil Dealer
Old 06-14-2011   #249
GsXtUrBo98
GsXtUrBo98's Avatar
Not at the moment.. I will though eventually
98 GSX (built)
03 BBY EVO dd
Old 06-14-2011   #250
95talonracer
Finally Tuned...
Drives: Spyder GSX
Nice. So up and running this weekend?
Amsoil Dealer
Old 06-14-2011   #251
lol. sounds like it will be ready to rock real soon.
Old 06-15-2011   #252
GsXtUrBo98
GsXtUrBo98's Avatar
It drives but I need those parts and such I wouldn't be ready to womp on it anytime real soon I just feel so far away from that at the moment...
98 GSX (built)
03 BBY EVO dd
Old 06-15-2011   #253
mike55112
mike55112's Avatar
Drives: 04 evo
You have about an hour or 2 left of work. Get it done and get it tuned before next weekend
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 06-17-2011   #254
GsXtUrBo98
GsXtUrBo98's Avatar
Well I'm back to being stumped on my clutch... It is engaging close to the floor but not all the way.. I adjusted he clutch the way you are suppose to do it and I'm getting this.. I am going to bleed the clutch/slave 1 more time and if this doesn't correct the problem idk what else to do.. I really don't want to have to pull my tranny but if I have to then I guess I have to. Also, I checked the clutch fork and it looks good but not only that when the clutch is to the floor the fork is all the way to the passenger side which makes me think that I'm in good shape with that. Any thoughts would be great.
98 GSX (built)
03 BBY EVO dd
Old 06-17-2011   #255
95talonracer
Finally Tuned...
Drives: Spyder GSX
What method did you take to bleed it? Did you bleed all new fluid from the reservoir to the slave completely?
Amsoil Dealer
Old 06-17-2011   #256
blackawdtsi
Drives: 2G DSM
Just to make sure you have the right info...
Shimming Pivot Ball
http://www.teamrip.com/when_why_and_...ball_info.html
Pedal Adjustment
http://www.teamrip.com/clutch_pedal_...ment_info.html
Bleeding Clutch (make sure you do steps 11 and up)
http://www.teamrip.com/how_to_proper...utch_info.html
I don't know if you're running a 1g or 2g trans but maybe try installing the 2g restrictor if you're using a 1g trans.
IF all those fail you can try running an Isuzu slave. It requires a little trimming but makes the pedal lighter and engagement longer.
Old 06-17-2011   #257
GsXtUrBo98
GsXtUrBo98's Avatar
Yes I did this. BUT when I was trying to bleed the slave and was holding it in, when they pushed on the clutch slowly it pushed the slave out so I'm hoping that the slave just needs to be bled some more.. Also, I am going to re re readjust my clutch peddle and see what happens. Also, the like I said before my clutch fork makes full movement towards the passenger side and couldn't move any farther.
98 GSX (built)
03 BBY EVO dd
Old 06-17-2011   #258
blackawdtsi
Drives: 2G DSM
So it's making contact with the trans case?
Old 06-18-2011   #259
GsXtUrBo98
GsXtUrBo98's Avatar
Not quite that far. That's too much.
98 GSX (built)
03 BBY EVO dd
Old 06-21-2011   #260
GsXtUrBo98
GsXtUrBo98's Avatar
well I ordered some new tb shaft seals just to find out that the 1g n/a throttle body has different seals in it... Turbo ones are 14mm x 10mm x 3mm and the n/a's are 14mm x 10mm x 2mm..... So I read about this and people are taking the tb's to a machine shop and having them bore the recess 1mm deeper and sticking the turbo one's in. I think that this is what I am going to do. Others are just going to a parts store and getting the correct size and using just regular O rings in them.
98 GSX (built)
03 BBY EVO dd
