Old 05-26-2015   #241
Re: Project Black ValentNine AKA DSM9.0
Honestly I'd replace all pistons and have rods checked, at a minimum #3 and #2.
Old 05-26-2015   #242
Curious to what speeds you are seeing at DCTC, "back straight" for my ninja is around 95-102 most of the time, front straight is 70-85; with a bit left on the table in both scenarios. Corner speeds are pretty decent, but I have a long way to go!
By 'front straight' do you mean the straight right in front of the paddock? If so, second into third gear, probably 70mph?
'Back straight' is the part with the stop lights dangling from above? We usually setup that section with a slalom. There's another straight coming off of the east most carousel headed over to tht section that I've hit 4th gear in so probably 90?
Old 05-26-2015   #243
Can't wait for the rebuild, you sir, know how to do a comeback.
Good luck.
Old 05-27-2015   #244
cmspaz
Walls need hugs too
cmspaz's Avatar
I know I've hit 90 on the back straight. Front in my experience has been around 70.
Originally Posted by Trogdor
Old 05-27-2015   #245
Told you not to race a car that's for sale
Old 05-27-2015   #246
lol!! dsm9.0's name rings true. Sucks to hear scheides, hopefully can get it back up and running at a minimal cost!
Old 05-27-2015   #247
Mark Leasure
Mark Leasure's Avatar
Sorry to hear. Looks to me like a set of shelf stock HD2's, rod bearings, and a fresh set of valves. If the cylinder walls look good, you could do it like drop ins.
www.maperformance.com
Old 05-28-2015   #248
cmspaz
Walls need hugs too
cmspaz's Avatar
We wasn't racing doe.
Old 05-28-2015   #249
Oh right, "driver education event"
Old 05-28-2015   #250
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
If you time it, it's racing...sorry, you guys are silly not calling this racing, let's be honest here.
Old 05-28-2015   #251
Agreed 100%. It's a timed, closed course, event. It may not be wheel-to-wheel, but it's just as much racing as any other dragstrip, autocross, or HPDE.
Old 05-28-2015   #252
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Do you guys utilize transponders or just stop watches? If you use transponders, then i would think it's timed.
Spaz is the only one racing out there with all those numbers and graphics like a ricer LOL
Old 05-28-2015   #253
Murlo26
Murlo26's Avatar
Old 05-28-2015   #254
cmspaz
Walls need hugs too
cmspaz's Avatar
Everyone knows I'm a ricer attention whore.
There was no record kept of times at the autox/speed stop. They were intended for personal/instructor use to gauge improvement. If you want to argue racing, the only racing anyone was doing was against themself.
Old 05-28-2015   #255
lolz. Scheides did not win that race.
Old 05-28-2015   #256
Old 05-28-2015   #257
Racing, practice, whatever. I paid cash for the car and have good health insurance
More appropriate update:
Head is salvagable! Not only that but it'll be cheap to fix! $725 max. The machine shop said that they might have some used valves they can use from doing upgrades in the past OR they could just do +1mm valves in the car. I opted to KISS on this one since it's an IX and there's a lot more that can be done to add power before I start throwing extra money into headwork. Should be done mid next week.
Now I just need to grow a set of balls and figure out how to successfully replace the piston in cyl3....it really needs to go.
Old 05-28-2015   #258
Speedfreak
Drives: four tires
You checking/changing the bearings? I would. Also would replace all pistons and check rods as quoted above. Specially if selling the car.
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 05-28-2015   #259
1400HD's actually
Not 100% sure yet, never done this part before; still working through the details. For sure replacing piston in #3, gotta pull it apart a little more and see what I see.
Old 05-29-2015   #260
I've done the single piston replacement in car, it was a breeze. Car worked fine after the fact.
