Old 03-04-2009   #261
Re: Make slowboy not so slow
The other day I got a leakdown test. Compression was 160 +/- 3 across the board, with a loss of 9-14%, the middle two cylinders leaked the highest and had oil on the top of the pistons, which explains my huge oil burning issue.
Here is the plan for the next couple weeks:
Wednesday 3/11: Take off manifold/turbo/o2 housing, take them to Minneapolis with me and have them coated at MAP
Tuesday 3/17: Return to Iowa, remove head by Wednesday evening and have a local machine shop acquaintance check valve seals/guides, flatness, etc.
Saturday/Sunday 3/21-22: Have same guy come over with ball hone and ring filer, install new rings and bearings and hopefully get head back on and timing set by the end of the weekend.
I've never set timing before while the motor was in the car, I have no idea how to compress the tensioner, I need one of those screw thingys but I don't know how they work exactly.
Since the head and everything will be off, I'm debating deleting the ABS stuff since it should be pretty easy with that out of the way. I'll see if they have the parts at u-pull, or spend the $150 and get them all new from mitsu.
Old 03-04-2009   #262
Put the tensioner in a vise.
Old 03-04-2009   #263
Yea thats what I did before, used a c-clamp. How do I loosen everything then, undo the tensioner pulley? I don't have the tool to re-tension, maybe I'll borrow someone's when I'm up there next weekend.
Old 03-04-2009   #264
Just unbolt the tensioner or cut the timing belt or whatever. The hardest part will be when you need to re-tension it and get so that you can put the pin back in and out with it all set and tightened. It isn't an auto tensioner that you just pull the pin and let it expand.
Old 03-04-2009   #265
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
you can borrow mine andrew.
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 03-04-2009   #266
cmspaz
Walls need hugs too
cmspaz's Avatar
Now aren't you glad I have connections down there?
Originally Posted by Trogdor
Old 03-04-2009   #267
This is true, I couldn't have done this until June or later otherwise. Swifty I'll look you up next weekend and get that.
Old 03-04-2009   #268
Holy fuck dude, sounds intense. I have a tensioner tool as well, I'll trade you your dog for it Of course, it's actually only 1/3 mine, the other 2/3 is hughes and zac, so you'll have to offer them something too
Old 03-04-2009   #269
Hmmmm what do I want....
Its the nice hardened AMS one.
Old 03-04-2009   #270
good luck man. I havent seen your car in years.
Old 03-05-2009   #271
I hate engine problems.
Old 03-05-2009   #272
The only thing im wondering is how a motor with only a couple thousand miles has ruined rings already. Can a really bad break in process do this? I wouldn't think so but Im not sure.
Old 03-05-2009   #273
If the rings never seated properly then it would always burn oil, plus it was gapped pretty loose from the beginning. It also sat on a garage floor for 3 years after the first 1000 miles, probably doesn't help.
Old 03-05-2009   #274
cmspaz
Walls need hugs too
cmspaz's Avatar
^Troof.
Not only was it a garage floor, it was a garage floor in Ames, Iowa.
Old 03-05-2009   #275
Swifty1638
Swifty1638's Avatar
didn't you see it last year at a dyno day aaron?
I also ponder if the rings really are bad..
-A. Swift
Black 1GB Mafia #1
I wanna go fast.
Old 03-05-2009   #276
An engine sitting covered up and sitting for a couple years wouldnt have any effect on rings going bad. The only thing I could see happening from that is surface rust on the cylinders, which would be bad.
I suppose seating the rings could have been the issue. I just would think with all his experience with engines, he would know what to do with engine break in.
Old 03-05-2009   #277
Well, I guess what are the alternatives? A really bad leaking head? The car pushes a little coolant, but I've only filled it up once or twice in a year so thats not bad, so the headgasket isn't really blown. I just don't know what else it could be, lightly cracked block or something?
Symptoms:
1. 160 compression on 9.0:1 pistons - I'd expect 180-190
2. Burns 1qt oil every ~700 miles
3. Burns a TON of oil after a pull on decel or between gears
4. Crankcase pressurized, dipstick popped out once before I crushed the tube a bit
5. Ton of blowby into catch can, need to empty every oil change, also letting some oil into intake/turbo/piping
Old 03-05-2009   #278
Swifty1638
Swifty1638's Avatar
I guess that's just not something I'd guess at.
-A. Swift
Black 1GB Mafia #1
I wanna go fast.
Old 03-06-2009   #279
Well shit. I don't think I can get the rings in time now since I have to return the wrong ones I ordered. Still waiting to hear back from Magnus on the exact specs that were ordered, I don't want to have to order them again.
Still taking off my turbo parts to be ceramic coated though, but the rering may have to wait until after the cruise.
Old 03-07-2009   #280
I just want to throw this out there, but did you check all the valve stem seals and guides?
