Build the X 17 56.67%
Old 06-24-2013   #1
You sure your woman will let you leave the house?
Old 06-24-2013   #2
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Better check, good call, don't want to piss her off
Old 06-24-2013   #3
LOL
Old 06-24-2013   #4
93gtpeater
Drives: cbr 1000rr repsol
Did you sign up Murlo? Wish I would of known sooner about this.
Old 06-24-2013   #5
Murlo26
Murlo26's Avatar
Yea a long time ago I did.
Old 06-24-2013   #6
Murlo26
Murlo26's Avatar
Is RKC still happening even?
Old 06-24-2013   #7
93gtpeater
Yes rkc still happening
Old 06-24-2013   #8
Murlo26
Murlo26's Avatar
Time? I am 50/50 on it but leaning toward yes. so maybe 51/49
Old 06-24-2013   #9
93gtpeater
I will be there around 615.
Old 06-27-2013   #10
Old 06-27-2013   #11
Murlo26
Murlo26's Avatar
Yep, buying those for the new build.
I also think I have decided on going ported OEM ported exhaust manifold again and a recirc downpipe probably to quiet it up again. If I am not going for stupid high power no sense in having all that lol.
I think I will probably go EF2.5 as well, rev to 8k on street (9k at track if needed) and shoot for 500whp. Then do a wally 255 with modded relief in the tank and go BAP if needed.
SO I will need a BUNCH of stuff to get the car to this but I am in no rush. I think the car will drive a whole lot easier, idle/drive better and be stock like spool. Should be interesting coming back down 250whp. Hopefully I don't get bored, if I do I sell it
Old 06-27-2013   #12
Tachyon
Tachyon's Avatar
Drives: Icarus
Sounds like a solid plan. If you stir in turning the wheel along with 'only' 500 WHP, it's going to take a long time to get bored of the setup.
Totally give circuit racing a try when you're able. I think you will be very very pleased.
-Sebastian Vettel
Old 06-27-2013   #13
Murlo26
Murlo26's Avatar
I plan to for sure, I'd like to do more road course stuff, the X is made for that. But that is also expensive.
Future I am going to look at getting a 17" slick setup on my car. I just don't want to have to go through 1200+ dollar tires and brakes all the time doing road courses. But I for sure will do some HPDE stuff at some point.
Also want to focus on the "small" stuff I have neglected. Rotors, driveshaft and taking weight out.
I just love the "Ron Method of Attack" with his 9 RS. That thing can do it all, perfect evo there. I just wish the X weighed less. I have to learn to drive for that method though too
Old 06-27-2013   #14
You will appreciate both of these things. I experimented with a tubular last year but the ported cast just takes so much worry out of the equation (plus I picked up 10wtq while only losing 3whp while on the EF2).
Old 06-27-2013   #15
Are you sticking to E85 or switching back to 93?
Old 06-27-2013   #16
Murlo26
Murlo26's Avatar
Corn. Safer on my compression.
Old 06-27-2013   #17
Oh that's right, you already told me that...
I'm curious to see if a single Wally will be enough to supply an 2.2L w/EF2.5...I definitely have my doubts. I honestly don't think my fuel setup (Walbro 255HP w/ID1k injectors) would support my car on E85 unless the tune was purposely held back.
Old 06-27-2013   #18
Murlo26
Murlo26's Avatar
Future plans still include a surge tank, so I don't want a big ass 450 in there. PLus the 450 was causing some pretty high idle pressures hardwired. And with 2150's and high base pressure that sucks for idle!
I just want to simplify everything and hopefully get some more "proven" shit in there. A 255 to me is very proven. I think with an AFPR and my 6AN feed line and 1300's I will be close for the 2.5 on corn. We will see. If not, I will just run with 450whp and keep it all safe. Then get the surge tank with wally 450 in it like I had planned.
Old 06-27-2013   #19
Tachyon
Tachyon's Avatar
Drives: Icarus
I feel the same way.
Based on what I've experienced over the past 2 weeks with maxing out a single 255, I'd would agree.
-Sebastian Vettel
Old 06-27-2013   #20
Murlo26
Murlo26's Avatar
If that is the case, maybe I will look at something else.
I was under the impression the wally 255 was good for 600whp or so (dynojet, not Shane DB dyno) on 93 and roughly 500whp e85.
Like I said I wouldn't mind stopping around 475whp or so if I need headroom. I could run higher base pressure too if need be as I am not planning to run 35psi or anything anyway.
I guess we will see.
Tags
