Old 05-08-2014   #281
Re: Carl's 98 auto AWD project Black Magic
How much is it with the discount?
Old 05-08-2014   #282
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
WTF did they start making the front covers out of gold? I swear when I built my 6 bolt it was only like $100. I just checked on Maps site and the 7 bolt is over $400. I'll part the fucker before I pay that much for a oil pump.
11.35 @ 120mph
Old 05-08-2014   #283
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Sucky but holy carnage. Nice
2006 WW IX RS 396/404 - SOLD
Old 05-09-2014   #284
dsmreck
dsmreck's Avatar
Drives: 98 gsx
I think gst racer wants $125 for his. Legit guy, he is parting his car out
Old 05-10-2014   #285
Fuuuuck. That thing really went
Old 05-14-2014   #286
carltalon
carltalon's Avatar
I took the head apart today, so that means more carnage pics.
I'm starting to get discouraged. I just keep finding more and more things that are going to cost money.
This is the combustion chamber of the cylinder that dropped the valve.
Bent valves I think these are the intake valves from cly. 4
wear on the cam journals I'm starting to think I might have had a oiling issue some time before the rod went . hopefully these can be polished but I'm not getting my hopes up.
E85 "black goo" build up only on the cly that the rod blew. I think this might have been the cause of the failure.
you can see all the other injectors are clean except #2 that blew.
"black goo" build up in #2 intake port but not #1
11.35 @ 120mph
Old 05-14-2014   #287
That damn goo, wonder what oems do on their flex fuel cars to address that.
Old 05-14-2014   #288
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Black goo. Bleh. That's lame as hell. Is it just me or does the lobe on the left in picture three look odd? The lines in it. Almost looks like a crack. I'm sure it isn't but yikes.
Old 05-15-2014   #289
You mean the lobe on the right?
Old 05-15-2014   #290
carltalon
carltalon's Avatar
I usually get my fuel from the same station and switch back to regular gas at the end of the season and Ive never had a problem before. last year I didnt switch back and this is what I found.
The lobe was scratched from when I tossed a rocker last year. I buffed it out and figured it was good to go since it runs on the roller.
DSMINMN, lets just say you were back in school . can you quote me a price on doing the head with all new valves , guides and 2 new seats? I can tale care of the damage to the combustion chamber .
11.35 @ 120mph
Old 05-15-2014   #291
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Indeed sir. I have been sleep deprived lately. Thank you for catching that.
It should be fine since it is a scratch. Granted I was in school and had the time you're looking at around $200 before driving down to get it and/or delivery. As well as assuming you supply the valves, guides, seats seals and such. It also depends on what type of guides you want to use. If they're bronze the price would reflect it because after knocking the new ones in you have to hone them and that takes a little bit of time.
Old 05-15-2014   #292
Carl, there's also a pretty affordable head place in Andover called Northern Cylinder Head. You could try giving them a buzz. They did lots of work for me and my buddy back in the day, extremely reasonable prices.
Old 05-15-2014   #293
DSMINMN
Mitsus for days!
DSMINMN's Avatar
There's also Headwerks in Bloomington. They do amazing work on everything and anything.
Old 05-15-2014   #294
And Gosh, right next to DB.
Old 05-15-2014   #295
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Tim zimmer has been telling me about a cleaner he has been running in his ethanol. I forget the brand but he says it's like magic at preventing buildup and does an awesome job cleaning also he says he rarely sees a change in afrs. .1/.2 at most. I'm deff going to give it a try as I also believe the goo can clog injectors or cause bad spray patterns. Hell I had to send my 2150 to fic because two won't even open to clean them. Also I may have some spare head parts. I have a spare 1g head but I assume you are running a 2g
Old 05-15-2014   #296
Please share when you remember the name of the cleaner.
Old 05-15-2014   #297
This.
Old 05-15-2014   #298
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Manhattan oil
Top lube
Part # 19769
Tim says he used grape I believe that's
Part # 19769-31
Says it smells super good like a mix of blue 110 and e85 obviously. They make multiple cents for experimentation of fuel smell. He says your eyes don't burn quite as bad either. This post=win
Old 05-15-2014   #299
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Manhattan oil
Top lube
Part # 19769
Part # 19769-31
Old 05-15-2014   #300
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Oops a post so nice it's there twice
