Build the X 17 56.67%
Old 04-30-2014   #1
Sounds like busch nuts will sell these to MAP for like 20 bucks. So I am just going to buy them from him so I know I am getting the right ones even though I am sure you are right and NAPA or someone probably has something. But 20 bucks seems reasonable.
You know Buschur finds the cheapest eBay clamp and marks it up 300% right? That's what he does with half the things he sells. LOL
Design won't matter one bit, if the pipe is round it will hold it on there all the same, unless you have square exhaust piping?
You wanna be smarter financially? Start by stop over spending.
http://www.amazon.com/Dynomax-33230-...+exhaust+clamp
Old 04-30-2014   #2
Silly Buschnuts and his crappy diesel truck parts... Like the semi-truck radiator hose he cuts up and calls intercooler couplers
Old 04-30-2014   #3
Go to the parts store they are well under 20.00 each.
Old 04-30-2014   #4
cmspaz
Walls need hugs too
cmspaz's Avatar
Yep, had them in stock at the O'Reilly store I worked for.
Originally Posted by Trogdor
Old 04-30-2014   #5
cmspaz
Walls need hugs too
cmspaz's Avatar
http://www.oreillyauto.com/site/c/de...0082&ppt=C0022
Old 04-30-2014   #6
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Thanks Spaz, looks like those are in stock near my house. I will go there then.
I never buy these, wasn't aware they were readily available everywhere, my bad. Thanks for the heads up guys.
Old 04-30-2014   #7
Had to get some 3" clamps like this for the Vette when I put in a Z06 exhaust, went to napa and they were under $10 each. Worked perfect.
Or I have two of those clamps pictured in 2.5" but the bolts should work for 3" if you want to reuse what you have. Free, I'll give them to someone on the cruise so you don't have to pay for shipping even.
Old 04-30-2014   #8
Murlo26
Murlo26's Avatar
The oriely ones are like 10 bucks, I'll just pick them up tonight from there on my way home. Thanks for the offer though Andrew, I appreciate it.
I am planning to work on the car this weekend quite a bit so I would rather just get them now.
Old 04-30-2014   #9
The bolts on that old clamp look like they were made from standard Buschur grade SS as well.
Old 04-30-2014   #10
Murlo26
Murlo26's Avatar
Yea, it bugs me they rusted so badly
The exhaust was like 850 bucks too. thankfully the tips still look new and the piping itself has held up.
Old 04-30-2014   #11
The nicest stainless Buschur sells is the rebranded Chinese eBay o2 housings, the rest of his crap is either mild steel or 409SS which rusts pretty badly after a salty winter. My Buschur clamps were trash after 1 winter/10k miles on my IX.
Old 05-03-2014   #12
Murlo26
Murlo26's Avatar
Dropped my turbo and exhaust manifold off at MAP yesterday for porting/coating. Then picked up these.
Anyone else used the ID1300's? It came with pins and plugs and it looks like I need to solder them on. I am Ok with doing that, although I prefer not to. Just curious if I could get drop in ones so I don't have to.
Anyway, working on my fuel pump install today.
Old 05-03-2014   #13
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Yeah I looked into them for my 8 I thought they have the plug and play adapters for them
2006 WW IX RS 396/404 - SOLD
Old 05-03-2014   #14
Ya those clamps are available everywhere, kinda nice it uses parts that are readily available honestly...been there on the rust though.
What's with the fuel pump I see lying there? Seems to say DW on it...
ID1300's, interesting. Not sure on the soldering of pins, that seems goofy. Good luck!
Old 05-03-2014   #15
Murlo26
Murlo26's Avatar
The fuel pump is AEM, its the AEM320. The DW box is for the relay and wires, its their hardwire kit.
I am going to check with MAP to see about getting me the PnP adapters, think they forgot them.
Old 05-03-2014   #16
Old 05-05-2014   #17
Get the ID PnP harnesses...do NOT get the FIC ones.
Old 05-05-2014   #18
Murlo26
Murlo26's Avatar
Ordered the ID ones. Bill and I both forgot about the adapters. I assumed they just came with the injectors and he forgot to ask so I didn't get them.
He is getting me some this week though I think, so problem solved, no soldering for now.
Old 05-08-2014   #19
Murlo26
Murlo26's Avatar
Got the ID PnP adapters yesterday and have the exhaust clamps as well ready to install.
Also got this from MAP.
Turbo inspected great! The only thing it needed was some seals and re-balance which we already did. Everything else checked out perfect! No need for bearings, thrust washer or any housings.
So the used turbo looked good I guess and is ready to rock. Sounds like it just needs coating so should be here end of next week I am hoping along with my manifold and downpipe and then its just time for install and tuning.
Old 05-10-2014   #20
Murlo26
Murlo26's Avatar
Downpipe is done, manifold will be done porting next monday/tuesday I think and then the following monday/tuesday the turbo, manifold and downpipe will be ready for pickup. Woo.
Working on the pump right now, but missing some pieces.
See this:
I sold the connector last year with my wally 400. Does anyone have a part number for something similar at like Napa or something?
Hopefully I don't get in trouble for asking this I'll probably head there tomorrow to poke around but figured I would ask as a a lot of you guys are quick with finding these things.
Here is the rough size:
Once I get this piece I can finish up the pump install and start in on intake mani next weekend I hope along with TB fuel rail and injectors etc.
Tags
