Build the X 17 56.67%
Old 07-16-2014   #1
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Not leaking bad, no. Just a bit. But after like 5-6 minutes of idle there was a small puddle, so needs to be dealt with. Yea looking at it I don't think it will be too bad. Ordering up some gaskets and putting new gaskets in with sealant on them Friday. then all should be good after burping the coolant system.
Then put undertray and bumper on and last wheel back on and drive!
Old 07-20-2014   #2
Murlo26
Murlo26's Avatar
So got the car's coolant leak fixed, yay. No more leaks, fluids anyway.
Found out my basically brand new 200 dollar battery is dead. I think my trickle charger must of killed it, no idea how but ya, no more leaving stuff on that.
Also, worse, found air leak on the intake manifold. It looks to be coming from the sealing surface between the head and intake mani, we could get the car to stumble by blowing compressed air there, so pretty sure.
I am using one of those MAP pheno-whatever (plastic) intake gaskets. I just had my intake mani ported in between last year and this so my thought is they cleaned up the mating surface and now it doesn't seal the same way it did before.
So, going to probably just order a stock intake gasket and then also a new battery this week and hopefully I can drive it this next weekend, we shall see.
Now just debating on a lithium battery or the pc625 or whatever.
Old 07-20-2014   #3
I have one of those phenolic spacers if you want it; uses stock gaskets on either side of it but they work great.
Old 07-20-2014   #4
Murlo26
Murlo26's Avatar
I think I am just going to use the stock one and say F it. Thanks though bud. I will let you know if I need it.
Old 07-21-2014   #5
The orange/brown ones require an OEM gasket on either side of it to seal properly; I do not like this design as it is more prone to leaking. The white ones do not require a gasket as they have a slight amount of squish to them (these are what I've used and recommend). I know people will claim otherwise, but I consider these to be single-use only like most other types of gaskets.
Old 07-21-2014   #6
cmspaz
Walls need hugs too
cmspaz's Avatar
Depends, I guess, since most other gaskets are "single use."
Originally Posted by Trogdor
Old 07-21-2014   #7
Murlo26
Murlo26's Avatar
I have the white one. It's the one MAP makes for our cars. I have had it since my fp black build. So its been reused several times.
Yep, I am guessing I should've replaced this gasket I will get a new OEM one this week and put it on this weekend. I trust the OEM one to seal properly vs one of those I guess.
Old 07-21-2014   #8
Get a new white one, reusing it that many times is your problem. They work well. I had one on my IX and X.
Old 07-21-2014   #9
Murlo26
Murlo26's Avatar
My buddy said those plastic ones can have sealing issues and said the OEM one is the safe bet.
Looks like MAP doesn't even make theirs anymore, at least its not on their site. And they only show the Boomba one which is 85 bucks.
http://www.maperformance.com/boomba-...shi-evo-x.html
Not sure what the hell all those bolts and that other piece are for pictured here...
Seems safter to go with this:
http://www.maperformance.com/oem-int...ion-evo-x.html
Is there a reason that it's not a good idea to do OEM?
Old 07-21-2014   #10
They're about $20, you just have to ask for one. Bill always knows what people are talking about when I refer them.
People say a lot of things, 99% of which have never actually touched the product...I use/recommend/trust things I've actually had good experiences with.
Your car so it's your call, but it sounds like you've had good luck with it thus-far, if anything, it went beyond expectations since you reused it multiple times! OEM is never a bad idea, it just leaves room for improvement on the table.
Old 07-21-2014   #11
Murlo26
Murlo26's Avatar
No I hear ya.
I just don't want to have to pull the intake mani apart again after I do it this week/weekend.
Especially since my buddy who is a mechanic for infiniti is helping and he recommended OEM. SO if I don't go OEM, he helps and it leaks still, he will kick me in the nuts lol.
I am fighting internally, as I don't want to leave power on the table but I just want it to work.
Old 07-21-2014   #12
Simple: See what's in-stock immediately available for wrenching this week
One side-note: Sometimes when manifolds get ported they slightly warp due to heat and the flange face isn't as true as it was from the factory; the white gasket allow for more squish than the OEM gasket does. Cobb had this issue with a ported IM (MAP Rev2) and the OEM gasket wouldn't seal it.
Old 07-21-2014   #13
Murlo26
Murlo26's Avatar
Well that was my thoughts as to why the leak is there, because I got a MAP rev3 since last time it was isntalled. So I assumed the white gasket I had was formed to the OEM manifold and after the porting, the surface changed slightly and it wouldn't seal.
If they have the white one in stock I will go for that I suppose. It's not the end of the world to do the IM twice I guess. And if it has more "squish" than OEM, that is probably a good thing.
Old 07-21-2014   #14
Murlo26
Murlo26's Avatar
Map doesn't make theirs anymore. But they sell this which I bought:
http://www.maperformance.com/gizzmo-...o-x-g6039.html
Bill said it was basically the same thing. Almost looks like this is what MAP maybe rebranded for theirs. Anyway, gasket and battery ordered (got the odyssey 680 instead of the 925 this time as its cheaper and lighter). My battery actually tested good at my buddies dealership but just didn't seem to want to start the car so not sure what gives. The car started fine when i left the charger on there though.
If this battery doesn't last I am going to put a normal one back in there or start checking my grounds as something has to be up with it.
Old 07-21-2014   #15
I had good luck with the STM battery kit I put in my car. Pretty nice for $150 shipped (battery, bracket, hardware, etc.).
Old 07-21-2014   #16
Murlo26
Murlo26's Avatar
I have all the hardware for the PC680. I have the AMS battery kit, just need a new battery and the PC680 should work the same.
Thanks though for the recommend
Old 07-21-2014   #17
Why not test that battery in your other car or in some other application, if it checks out on a tester? Id do that before ordering another expensive battery.
Old 07-21-2014   #18
simulatedwood
Drives: 08 Evolution X
I will run nothing but these batteies: check out the site.. expensive but they out perform anything you can get, and last forever. http://shop.antigravitybatteries.com...ries-ytx12-20/
Old 07-21-2014   #19
Order it up, that is badass!
Old 07-21-2014   #20
Murlo26
Murlo26's Avatar
That battery is too much Shawn, I would love to get it but I am tapped for car money. I just want to drive the damn thing. I went with the PC680 as they are relatively proven.
The guy who tested my other battery said its sadly very common that the tester shows it good but they still have to replace batteries to fix them. He saw it in action and agreed a new battery was in order, so I just ordered it as I just want to drive the car.
Tags
