Old 05-03-2009   #301
Re: My Talon
Ouch! I'd say that turbo is pretty much toast.
Old 05-03-2009   #302
Re: My Talon
I've seen worse damage than that on Holsets and my brother was still able to rebuild them at the diesel shop he works at.
Old 05-03-2009   #303
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: My Talon
OMG!!!! I didnt think it was going to be that bad. Sorry to see that man! Any idea on what you are going to do now?
Amsoil Dealer
Old 05-03-2009   #304
Re: My Talon
I thought these were supposed to be durable?
J/K, Sucks to hear man. What's your plans?
Old 05-03-2009   #305
Re: My Talon
I had the same thing happen to me, well the line was uber loose, but i noticed a new leak so i checked it.
ANother thing to check.
Old 05-03-2009   #306
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Re: My Talon
Wanna take our turbos and throw them at each other..we can see which will be more durable then! flippin car shits.
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 05-03-2009   #307
Re: My Talon
Haha, well the feedline fitting that screws into the center section came loose. I'm sure because the turbo had very little oil flow and almost no pressure as I was making a pull everything got hot, the shaft seized/broke, and the turbine wheel went crazy. It also tore up the BEP housing I have...
So I will see about getting the turbo rebuilt, if it's possible. It that works, I'll try my best to clean up the turbine housing with a die grinder and hope it works half-assed.
This isn't anything about the turbo being unreliable. I'd get a Holset again.
I might look into a PTE as a cheaper alternative IF I cannot repair this turbo.
Old 05-03-2009   #308
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: My Talon
SCM61 go for it!
Amsoil Dealer
Old 05-03-2009   #309
Re: My Talon
I was kidding about the reliable thing. Best of luck with it dude!
Old 05-03-2009   #310
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: My Talon
Yeah I heard about your car this morning. That really sucks since you just got it up and going not too long ago. But what can ya do..
-1990 Mitsubishi Cyborg 4WD-
Old 05-04-2009   #311
mike55112
mike55112's Avatar
Drives: 04 evo
Re: My Talon
I cant believe this happend, its crazy I was actually at my house when you called. Alyssa came in and said some car was on fire at the gas station and then i get a call from you. At least it wasnt the motor, I guess we all are not having the best of luck with our cars.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 05-04-2009   #312
Re: My Talon
weird man. sorry to hear.
Old 05-04-2009   #313
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Drives: 1990 Eclipse, 1991 Eclipse with a little Holset Sex
Re: My Talon
OUCH!
You can get a wh1e to bolt into your hx40 turbine housing. It has a 58mm 8blade compressor. Or just a standard 8blade 58mm inducer hx40. You don't need that 7blade or 6blade 60mm wheel. Not remotely for your horsepower. 8blade hx40, 535whp on a dynapack and 139mph with 2760lb race weight: Click. You have another 100hp to go before you should wonder about having the 60mm wheel. That could save you some $$$.
. . . Research holset fakes if you decide to get another holset. There's chinabay fake hx40s floating around. There's a thread on tuners about it. The word holset in the same font on the id plate that looks like a holset plate on the compressor cover and all. "xs power" pops up when you move the mouse over the pic. . .But You can spot the difference easily if you know what your'e lookign for. Holset is even pressing the issue with the authorities. Just a heads up if you're looking on ebay for a real holset.
Here's the thread. Click.
Matt
Bolton Holset H1C w/ external gate, fp2X cams, DSMLink, 3" exhaust, FMIC, water injection
"There is nothing better for man than to eat, drink, and see good for all his hard work." Solomon
wheelhop is offline   Reply With Quote
Old 05-04-2009   #314
Re: My Talon
I dropped it off at a local diesel shop. I even called a few places, pretty much everyone said I'll need a new center cartridge, if they can even ID the current one. Should be about, oh, $600... Booo.
All I know is that this is a 6-blade comp, 12 blade turbine, I got it brand new as just a HX40 for a DSM. Apprently there should be some part numbers on the back side of the compressor wheel, and they will hopefully try and match up that wheel with a new center section. I'd like to keep the 69lb/min comp wheel if possible. I won't be a stock 2.0L forever
Wheelhop do you know any part numbers for my 6 blade hx40?
Also, my turbine housing is a little messed up, guess I'll have to whip out the dremel!
Oh, and BEP housing for the lose: The bolt holes not tapped all the way through, my hardened steel turbo bolts missing 1/3 of their threads and a pain to remove.
Old 05-04-2009   #315
Re: My Talon
Or I'll just buy a new one lol cause I'm an idiot. or some lame PTE lol.
Old 05-04-2009   #316
Re: My Talon
Did you try East Central Diesel up in Cambridge? My brother works up there and they do pretty damn good work.
Old 05-04-2009   #317
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Re: My Talon
hx40 compresso part numbers
There are VERY few hx40s out there with the 6blade wheel from the factory. They usually come with the slightly faster spooling and slightly lower flowing 10blade hx40 turbine (will bolt right into any hx40 cut turbine housing).
Matt
Old 05-04-2009   #318
Re: My Talon
thanks.
Old 05-08-2009   #319
Re: My Talon
Ok. So I brought my turbo to diesel components, and I'm extremely happy I did.
After looking at the turbo, it wasn't lack of oil that caused the failure, but a turbine blade broke off and sent everything to shit. Diesel Components had a matching turbine blade in stock, and it was the same. They normally stock the CHRA I need but they were out and one should be in next week! I'm kinda pissed, kinda not, about the turbine blade. They said they have seen it happen before...
Old 05-08-2009   #320
Re: My Talon
I wonder how they determine that. Wouldn't a catastrophic failure of the Center Section destroy a turbine blade?
Glad to hear you're getting it worked out. Come to the track!!
