Old 12-17-2012   #1
Mark Leasure
Mark Leasure's Avatar
Re: Mark's 1G Winter Projects
I had a good weekend, worked on the car on Saturday for about 8 hrs. I co-located all of my gauges in the fabricated instrument cluster.
I’m going to cover up all of the old gauge location holes. I have not wired everything yet. About the wiring, I removed all of the unnecessary wiring that was just dead weight. I left all of the critical ECU functions and lighting wiring (headlights/parking, brake, turn signals, and reverse lights). I weighed everything after I was done removing it and it came up to 43 pounds!
I also picked up a 7/8” tandem master cylinder to remove the power brake booster too, I don’t know what the booster weighs, but if anything it will clear up the engine bay. I'm kicking around the idea of having the engine bay painted too, since almost everything has been removed.
www.maperformance.com
Old 12-17-2012   #2
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Nice, very impressive weight saving
2006 WW IX RS 396/404 - SOLD
Old 12-17-2012   #3
Yeah, I remember just getting rid of the ABS pump and wiring was an easy 50 lbs. Every bit makes a difference.
Old 12-17-2012   #4
Nice progress. I'd say go for it, paint the engine bay. I was personally on the fence a lot lately about cleaning things up on my car, getting things coated, etc. And once they were done, there was no more question and I was so glad I did it!
Old 12-17-2012   #5
Paint it up FOSHOOO
Old 12-17-2012   #6
43 pounds! Goddamn, I didn't relize you had that much more to rip out of this thing!
Old 12-17-2012   #7
Mark Leasure
Hell Yes!
I know the 1G's are horrible for wiring efficiencies; I was kind of shocked when I weighed everything out! Even more weight is going to come out of it. I haven’t even touched the doors yet, the factory crash beams are still there too! I cannot remember what the weight was the last time it was on the scale at BIR with me in it, but I know it was in the 27XX range and I’m about 210 with all the safety gear/helmet??? I should borrow someone's corner scales to find out for sure, but 43lbs so far is not bad!!!
Old 12-18-2012   #8
I can't believe you can keep pulling more weight out of this thing, but I love it!
Old 12-19-2012   #9
Mark Leasure
Yeah, the weight removal is going good. The doors and the manual brake conversion are next. I found a set of manual crank window assemblies that I purchased. I’m going to run lexan on the door glass but still have the ability to crank them down for very limited street driving, and it keeps it in street classes too. I'll hang onto the OEM glass just in case of classing restrictions too. I’ll also take out the crash beams and any anything else possible from the doors. I’ll keep track of the door project weight reduction too.
Old 12-20-2012   #10
Any estimate for how much weight you have pulled out of it this winter?
Old 12-21-2012   #11
Mark Leasure
50 ish so far? The goal is the car into the 24XX range with out me in it. Should make it faster and easier on the drive train too.
Old 12-20-2012   #12
The door beams weigh a bit, but not that much. It was probably about 2lbs each. The black tar paper/sound deadening stuff on the floor was more than that. Not sure if you have tackled that yet or not.
Old 12-20-2012   #13
I remember Shep saying something back in the day about the power window assemblies weighing hardly anything more than the manual ones. Speedglass side windows would make a difference though.
There's a lot of inner structure around the b-pillars down where the ABS computer used to be. Not sure how much of that you can take out, but there's definitely some fat to trim there.
Old 12-21-2012   #14
Mark Leasure
I was looking around and no one actually publishes the actual weight of the door bracing, but from some of the banter and judging by material thickness it looks to be north of 10 lbs each. I'll weigh them when I remove them and publish it.
Yep most of the deadening material has been removed too, I still have some left on the fire wall to remove. I exposed it after I took the HVAC box out.
They are light, but I removed the factory harness and I'm not going to power the doors for window functions. Both crank assemblies are around 3 lbs! I'll check into the ABS stuff, good recommendation!
Old 12-21-2012   #15
I am quite positive it wasn't anything close to that. I took mine out years ago and I remember thinking that all the work was definitely not worth it. I would guess it was about 5lbs each. The metal wasn't that thick for them. I didn't fully remove them though, just cut them off at the ends so I didn't have to drill the spot welds and possibly mess up the door skin.
Doing this saves 20lbs per door (factory glass is still in)-
Old 12-22-2012   #16
Mark Leasure
Just got the passenger side door weight reduction done. I weighed the crash beam and it came to just a little over 12 lbs. I took out the electric window motor and it weighed as much as both mechanical crank setups combined. Not that they weigh a lot. I’ll post a pic as soon as photobuckets site starts working again. Drilling spot welds was easy, I just wrapped tape around a drill bit so it could not penetrate too far into the door. I used piano wire to break the adhesive bond between the crash beam and the door skin. Then an air body saw to remove the door metal and an angle grinder to cut the beam. It took around an hour and a half to get it all wrapped up. Not bad for that type of weight savings!
I also took the brake booster out, it was a little lighter than what I expected at around 8 lbs. I need to machine an adaptor bracket to fit up the other master cylinder I ordered.
So far so good!
Old 12-22-2012   #17
Mark Leasure
Picture of door work
Old 12-22-2012   #18
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Looks nice...but sharp. Gonna cover it up with a bit of padding?
Old 12-23-2012   #19
Like.
Old 12-24-2012   #20
Mark Leasure
Originally Posted by Pushit2.0 View Post
Like.
Word
