Old 08-15-2012   #1
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: GsXtUrBo98's 2G project thread
Do you have another stock coil to try? How old does your coil look?
Amsoil Dealer
Old 08-15-2012   #2
blackawdtsi
Drives: 2G DSM
Better yet, what are their resistances?
Old 08-15-2012   #3
93gtpeater
Drives: cbr 1000rr repsol
You could have a bad plug. I know you said they are brand new but one could be bad. I had that happen to me before. You spark plug wires could be shorten out. You have a good battery and volts?
Old 08-15-2012   #4
95talonracer
Finally Tuned...
Drives: Spyder GSX
Did you also try new quality wires?
Amsoil Dealer
Old 08-15-2012   #5
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
I have Taylor 10mm wires that I bought just before Brainerd last year. I have an extra set of plugs that I could throw in there and see if it does anything.. One coil was bad last year so I swapped it out and all was fine. I have a brand new yellow top battery in my car as well.
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 08-15-2012   #6
No reason, I actually run bpr7es, but wanted to try br7es heard some good things plus seems like no-one stocks bpr's up this way.
Old 08-15-2012   #7
93gtpeater
Do you have a volt gauge to make sure you have enough volts? Somebody last year had a problem they werent getting enough volts. just throwing stuff out there try to help.
Old 08-15-2012   #8
GsXtUrBo98
GsXtUrBo98's Avatar
I don't.. Both times Shane tuned it I had a alternator cel.. I might just get a new alternator and see what that does.
98 GSX (built)
03 BBY EVO dd
Old 08-15-2012   #9
We usually use the BR plugs on nitrous cars and maybe some crazy high builds. Might lose some compression ratio with the short plug though.
Old 01-20-2013   #10
GsXtUrBo98
GsXtUrBo98's Avatar
What alternator should I get? I've heard a saturn one is good but also a galant vr4 one too? which is better? I want to get this thing ready for proving grounds this year! gonna be a beast if my plans pull through. I'm keeping my current setup but want to fix the break up issues and see if I can turn up the boost to make the 600awhp mark. I want at least 35 psi as I made 542awhp in shoot out mode on Shanes dyno. Whatever it takes and let er buck!
98 GSX (built)
03 BBY EVO dd
Old 01-20-2013   #11
The galant one will just bolt right up, have you checked your grounds?
I'd add some too, it can't hurt.
Old 01-20-2013   #12
GsXtUrBo98
GsXtUrBo98's Avatar
Ya my grounds are legit. I guess i could add more but the alternator cel has been there for years.. Lol i know i suck ha ha
98 GSX (built)
03 BBY EVO dd
Old 03-10-2013   #13
GsXtUrBo98
GsXtUrBo98's Avatar
I picked up a new/used alternator from Nick (Cornfed2.4) but I'm running into probelms. No fuel pressure and I'm not hearing my fuel pump turn on at all... I am no wire wiz so this sucks.. I checked in line fueses and they all seem legit so I'm not quite sure where to start.. I know I should be checking voltage but I suck at doing that lol. Wiring is the worst of my abillities of working on my car.
I want this thing ready for proving grounds this year! haha
98 GSX (built)
03 BBY EVO dd
Old 03-10-2013   #14
4seasons69
4seasons69's Avatar
Is the car at your place? I could maybe swing over sometime this week or next weekend and help you with it
Old 03-10-2013   #15
Maybe check the fuse on the boost a pump. Mine blew once which left me stranded with no power going to the pump.
Old 03-10-2013   #16
blackawdtsi
Drives: 2G DSM
Same thing happened to be with your old BAP... Except I was at RF. I had to jumper wire it to run again and get home.
Old 03-10-2013   #17
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
+1 for what brad said. There is also the mpi relay under the dash that may have gone bad. It's a gold box located under the radio on the right side.
Old 03-10-2013   #18
GsXtUrBo98
GsXtUrBo98's Avatar
I checked all in line fuses including the BAP.. And yes it'a located at my place still. That would be cool if you were able to swing by and give a hand sometime this week.
98 GSX (built)
03 BBY EVO dd
Old 03-10-2013   #19
4seasons69
4seasons69's Avatar
Alrighty. Sounds good. I'm Monday and Wednesday I'll be free later in the evening, Thursday I think I'm working on the talon, and them Friday I'll probably be free and Saturday after work. I'll text you tonight or tomorrow and we can figure something out.
Old 03-10-2013   #20
GsXtUrBo98
GsXtUrBo98's Avatar
Sounds good man
98 GSX (built)
03 BBY EVO dd
