Old 05-03-2013   #1
4seasons69
4seasons69's Avatar
Re: my new project
Are they 16's or 17's? Just get some of the M&H Racemasters and use them for the track and street.
My kosei's are 16's. That's what I was thinking. Or at least some type of drag radials. Drag radials might not perform as good at the track but this car will be seeing limited track time for probably the next few years. So i really don't need a dedicated set of track wheels and slicks
Old 05-03-2013   #2
Re: my new project
35 is low for a 6766, that birch will do 50!
Old 05-03-2013   #3
4seasons69
4seasons69's Avatar
Re: my new project
Lol touché. But an untuned 35psi isn't worth the risk ;-)
Old 05-04-2013   #4
Re: my new project
I thought it was tuned at 35?
I mean I thought Shane tuned it at low boost?
Old 05-04-2013   #5
4seasons69
4seasons69's Avatar
Wink Re: my new project
We were getting such a big drop in fuel pressure he couldn't really tune wot. I mean if my fuel pressure issue is fixed if I do a pull right now it should be dumping a ton of fuel and go really rich. I'm getting back on the dyno on Tuesday so I figure I will just play it safe and wait till the tune is finished. Hell I've waited a year already what's a few more days lol
Old 05-04-2013   #6
Re: my new project
True. Make sure you learn something when you dyno, that way if something happens on the street you can adjust your tune and save your car.
Old 05-04-2013   #7
Re: my new project
Or just get the wideband working and wired correctly and have the AEM do it on it's own.
If fuel pressure drops bad though, then no amount of adding fuel to the maps will make a difference. You could wire a fuel pressure sensor into the AEM also and have it adjust the fuel for small fuel pressure drops. Some factory ECUs actually do this. Some cars with factory fuel tanks and poor venting can go lean in the higher gears on a long run due to the fuel pressure dropping because vacuum builds up in the fuel tank and then the often already close to maxed fuel pump has to work a lot harder.
Old 05-04-2013   #8
4seasons69
4seasons69's Avatar
Re: my new project
I would love to learn something while I'm there! but I hate when people sit and look over my shoulder when I'm working on their cars at work lol. So I usually just stay out of shanes way and let him do his thing unless he needs me to do something.
Good luck, hope you can get you goal!
Watch out for the liter bikes there can be a 10-20mph trap difference!
Thanks! I'm not too concerned with whether I win or lose. If I can hang with them I'll be happy. If I lose I lose
As for the wideband being wired in to the aem it supposedly already is. But I'm still waiting to get my new laptop. I'm not sure I trust the old fjo in the car anyway. I want to verify it's readings match up with what your dyno reads. If it does I will make sure to get it properly wired into the aem. If it doesn't then it will be replace and I will get the new one wired in properly.
I have been looking into fuel pressure gauges with a 5v reference and it seems that aem is the only one that makes one. so that is one of those is on my top priority of things to buy for the car.
Old 05-04-2013   #9
URV8SUX
URV8SUX's Avatar
Re: my new project
Old 05-04-2013   #10
Re: my new project
Well there you go, already has a small failsafe.
Old 05-04-2013   #11
Re: my new project
What about one of the AEM failsafe wideband/boost gauges?
Old 05-04-2013   #12
4seasons69
4seasons69's Avatar
Re: my new project
Indeed!
This would be a good Idea but I would want to use it to replace my current boost gauge and it looks as though the aem failsafe only reads to 30psi.
Old 05-04-2013   #13
4seasons69
4seasons69's Avatar
Re: my new project
So I replaced the broken mounting bolt for my alternator today. When the bolt broke the spacer for the alternator relocation kit was lost so I made my own out of washers until I can order a new one from Jay racing. So the car is ready to go for Tuesday!
Old 05-04-2013   #14
Re: my new project
You could just use the failsafe as a wideband and keep your current boost gauge.
Old 05-04-2013   #15
4seasons69
4seasons69's Avatar
Re: my new project
I could but Idk if I could justify spending that much on a wideband that uses the bosch sensor unless I could use the boost gauge too
Old 05-05-2013   #16
Re: my new project
The failsafe features alone would make it worth it, unless your ems can already do that of course.
Old 05-05-2013   #17
4seasons69
4seasons69's Avatar
Re: my new project
I'm on not too familiar with aem so idk what kind of built in failsafes it has. I know Shane said it can adjust fueling based on afr and fuel psi inputs.
Old 05-06-2013   #18
4seasons69
4seasons69's Avatar
Re: my new project
Well I had my buddy bring the car up to db earlier today. Then i went up and took it for a spin tonight. Everything seems good to go. So hopefully goes better than last time ha
Old 05-07-2013   #19
Re: my new project
Is it getting tuned today?
Old 05-07-2013   #20
LingLing
AznKraut
LingLing's Avatar
Re: my new project
Yep, today at 6.
Bring the bike up to the shop Brad!
