Old 01-04-2004   #21
I figure you guys are doing that because you're going for the big power and drag racing. I'm working toward building my car for road racing, so with that in mind would removing the oil squirters be a wise thing?
Old 01-04-2004   #22
No. Oil squirters aren't as needed in drag cars. In a road race car you want every thing you can get to try to keep your engine cool.
Old 01-04-2004   #23
Raptor
ConArtist
Raptor's Avatar
Exactly. For shep and others that mostly only run the 1/4 it really doesn't matter. They do say coating the pistons can be an adequate substitute for the squirters on the street.
As for the knock sensor, I have read somewhere that one guy modified one of the freeze plugs and put it back in which is close to the original location. You could probably get one machined for press fit out of steel and even have a step left in the side so it would help keep it in place. Maybe add a little JB weld for extra safety. I am sure that would solve the problem and be safer than drilling new holes in the casting on the block.
Looks like the white whale should be hauling ass pretty well now. As long as Mike doesn't have a geriatric nap attack while staging.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 01-04-2004   #24
I'm thinking about installing an "air to oil" oil cooler also which will keep the pistons cooler with what oil does hit the back of them from the rods & crank. Don't forget about that 160 deg thermostat also.
Old 01-05-2004   #25
Originally posted by 1ViciousGSX+Jan 4 2004, 12:36 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (1ViciousGSX @ Jan 4 2004, 12:36 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Goat Blower@Jan 3 2004, 11:07 PM
Is this the same as your block?
Did you get that pic from a site dedicated to 2.4L issues? [/b][/quote]
It's an old picture gallery someone put up a while back when 2.4's were unheard of. The pics are of a G64B block, the ones I sold recently were the G64CS blocks, not sure which one you have. I'd guess Marco probably ground off the identification.
Besides that site, I haven't found much on the 2.4 info, mostly pieces in the NABR archives.
Old 01-05-2004   #26
Yeah, I've got one on mine. Not sure how much cooler the air model is than the sandwich type, but I was going for the minimalist approach, and wanted to eliminate as many oil and coolant lines around the engine as possible.
Old 01-24-2004   #27
I've been asked to post updates on how this engine build-up is coming, so rather than start a new thread I figured I would just add to this one.
Front cover assmbly installed and oil pan ready to go on.
Oil pan on
Cometic HP gasket in place
Cylinder head torqued in place
One note:
I had to slightly shave down the diameter of the ARP nut shoulder on 4 of the stud nuts to clear the valve springs and shims. Has anybody seen this before? I was surprised by that. I guess Marco used over-sized springs on the head.
I'm at the point now where I will be pulling out my old engine to start swapping parts (cam, gears, rockers, etc.).
Old 01-24-2004   #28
yes if seen that before. on my car and 2 of my friends. I just got a punch and a hammer and just hammered em down in there. But it's not like i have a brand new expensive ass setup like yours, so i was willing to break out a hammer on mine!
Old 01-24-2004   #29
ACRucrazy
Whao! Nice...
looks like my 2.4 setup I had goin for my ACR..... then I sold it all before it was installed.
Kinda scary thowin together a $7000 motor for a neon.... Kaboom would suxors! :razz2:
Slow stuff
Old 01-24-2004   #30
BuildADSM
looking good. When you pull the old motor could you mabey do a pic with both of them side by side so you can see any difference in them (if any noticeable from the outside). I was just wondering if there was much if any difference.
Old 01-25-2004   #31
Yeah, I was thinking about doing that anyway.
I think the most noticable difference will be the size of the ports (intake & exhaust).
Old 01-25-2004   #32
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
The new motor is cleaner, and the block is slightly (not noticeable in a picture) taller.
Old 01-25-2004   #33
Yeah, if you can see an extra 6 mm in deck height without using the timing belt cover as a guide, I'd be impressed.
Old 01-25-2004   #34
Raptor
ConArtist
Raptor's Avatar
He is probably used to seeing something only 6mm in length so his eyes are well trained. :stick:
651-488-7774
Old 01-25-2004   #35
LMAO hahaha
Old 01-31-2004   #36
Well my car started sputtering, coughing, and choking today, then it finally spit out a nasty hair ball.
It feels much better now.
Old 01-31-2004   #37
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
:drool: I love white DSMs/cars.
'04 Honda Ricer: stock
Old 01-31-2004   #38
Mike is the dealership you work at allowing you to use their space for 'the big project'?
Old 01-31-2004   #39
Yeah, with a little persuasion.
Old 01-31-2004   #40
God, that second pic looks all too familar to me.
