Old 05-06-2006   #21
twack
It was a auto get over it
twack's Avatar
Re: Anyone goin to RF this saturday?
i want to take mine out but still tuning. saw jakes turbo the other day, while looking for coolant lines, things friggin massive. thanks for the lines jake
Old 05-06-2006   #22
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Here are more pictures... http://www.vasso.net/jake/
The car is AWD... Fully built motor and everything is supported. Its running good but having a little problem with the tune so I might not race tomorrow but I will still go to the track.
Also, the turbo is not a 42r. It is similar but not entirely the same. It has a smaller exhaust wheel and close to the same size compressor wheel in one of the models, yet it still uses the same compressor housing. It has a P-Trim exhaust wheel with a .68A/R turbine housing and a 72mm compressor wheel. I just am completely amazed that it fit so well. The turbo is so massive yet it clears everything.
I had to make 2 modifications, grind a little off the bracing on the DNP manifold and cut a little out of the cross member for the lower IC piping to attach to the turbo. Other than that it fits perfect. Oh and dent the water pipe slightly. Not very much at all. Spools good and pulls very hard. I'm impressed with it.
Originally Posted by shoutbox
Old 05-06-2006   #23
tim
tim's Avatar
So did anyone go? How did everyone do?
Old 05-06-2006   #24
Shotgun!
Totenritt
Shotgun!'s Avatar
Yeah, what da deal, yo?
Old 05-06-2006   #25
Onefast99gsx
Good Gosh! that turbo is huge! Are you sure you have the right one. That looks like something off a catapiller earthmover. Probably start spooling at about 7000 rpms -eh?
What's with all the metal shavings? Hope none of that got in the inlet.
Old 05-06-2006   #26
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
I was there for a few minutes but I took my g/f's car seeing mine was still having some problems. I just went there to drop off some parts and saw some runs then left cause I had other stuff to do. Didnt look that busy at all. Seemed like there were very few cars there, but I also didnt show up until 1pm.
I see 1lb of boost on that turbo at 5500rpms. Lag is over rated. The metal shavings were from me having to grind on the support bracket that is attached to the DNP manifold. No shavings went into the turbo. Its nice, I like it, just wish I could get this damn thing running right.
Old 05-07-2006   #27
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
12.61 @ 108.9mph. Clutch is completely gone now... oh well. I will have a Tilton twin disc ordered.
'04 Honda Ricer: stock
Old 05-07-2006   #28
tim
tim's Avatar
Oh darn, time to upgrade. Sometimes it is nice to be forced into upgrading
Old 05-07-2006   #29
Onefast99gsx
Nothing wrong with 12.61, IMO- Anything in the 12's is a respectable time. I'd rather have a reliable 12 second car(which I do), than a 10 sec. car that's on jack stands most of the time.
Old 05-07-2006   #30
How much boost were you running Cher? The trap and ET seems low for your mods. Ryans EVO ran 12.6@110 with less mods than yours has (cams/AEM). Or was the clutch holding you back from really launching the fuck out of it?
Old 05-08-2006   #31
Drives: 98 iVTEC
Who knows what was going on. I was expecting a better MPH too. I was running 20-21 psi on 92 octane. The clutch is just completely toast as when it sees 1 psi of boost, it slips like mad. :-S
Old 05-08-2006   #32
I would guess with your mods and a good tune it should be trapping at about 113 or so. Its probably running a bit rich or you have the knock table setup pretty aggressive. Either way a 12 is a 12.
Old 05-09-2006   #33
b35talon
Drives: 92 TSI AWD
Were there many dsms there? A friend of mine went in his red 98 gsx and ran 13 flat. He said he didn't see many dsms there. He said he might have been the only t/e/l there. Either that or he wasn't really paying attention.
b35talon is offline   Reply With Quote
Old 05-09-2006   #34
I didn't see 1 turbo dsm run all day. There were 4 or so non turbo's running around.
Anyone notice the "my car doesn't have a hood" craze?
Old 05-09-2006   #35
Onefast99gsx
That's the way it always is. 8 DSM people saying they're going/racing and like 2 show up. That's why it does no good to get a poll days before.
