Old 09-02-2006   #21
rst95eclipse
Re: 1g 2g swap complete...Wont start
I've been following this thread and these are my thoughts:
Did you seal off anything in the intake/charge tract with a rag?
Do you have fuel pressure?
Are your injectors not plugged in the right order (harnesses)?
Are the plugs in the right order?
Are you throwing any CELs and if so what are they?
Old 09-02-2006   #22
Shotgun!
Totenritt
Shotgun!'s Avatar
Don't forget to cup the balls
Old 09-02-2006   #23
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Ok now I went out and checked each indavidual spark and the 2 sets of plugs do as follows
SPARK - - - spark - - - spark - - - spark and so on like i think it should and the other two do this
Spark - spark - spark - spark - spark so eother one isnt getting enough spark or the other is sparking too much burning the fuel off when the valves are open. If this makes since or you have seen this before let me know. Also do you think that this could be the CAS being bad? I dont see where else it would cross.
Old 09-02-2006   #24
elko51racer
have you checked spark with a screw driver? its a easy trick thats real old school, we use it a lot on the circle track cars, I mean yah you keep saying you have spark but that test is a for sure tell if you have it... and also check your throttle position sensor and your coolant temp sensor if either read incorrect it alters yours fuel and can cause that problem
elko51racer is offline   Reply With Quote
Old 09-02-2006   #25
95talonracer
Finally Tuned...
Drives: Spyder GSX
Which one is the coolant temp sensor on the 1g? iis it the one white plug on the upper of the thermosata area or the black one on the lower part?
I also tryed a new CAS and that didnt help so...
Old 09-02-2006   #26
95talonracer
Finally Tuned...
Drives: Spyder GSX
Still nothing. Any ideas?
Old 09-02-2006   #27
95talonracer
Finally Tuned...
Drives: Spyder GSX
I am down to thinking that it has to do with something that makes it spark abnormal as listed above. Any ideas let me know. Could the ecu do this? It ran 100% before swaping the tranny and motor.
Old 09-03-2006   #28
95talonracer
Finally Tuned...
Drives: Spyder GSX
Any more ideas here?
Old 09-03-2006   #29
rst95eclipse
If you're positive that it's the ignition, start with the plugs and work your way back. Plugs, wires, coil, wiring harness, ECU. Check your ground. Make sure you're timing is correct.
Old 09-03-2006   #31
Boostin_dreams
Send a message via AIM to Boostin_dreams
When Kyle at MAPreformance did my 6-bolt swap in my 95 it also wouldn't start. It would barely turnover then just immeadiatley shut off. He messed around with a few things and found out that it was the firing order. Try messing with it some more.
Boostin_dreams is offline   Reply With Quote
Old 09-03-2006   #32
95talonracer
Finally Tuned...
Drives: Spyder GSX
The spark seems to be wierd as stated above. I know that it is wired correctly unless the 95s are way different. Let me know. It has fuel and spark and I am down to the very end with ideas? If you have done the swap on a 95 and have had similar problems let me know.
Old 09-03-2006   #33
95talonracer
Finally Tuned...
Drives: Spyder GSX
Since I have spark does anyone think that it could just come down to the ecu being bad for some reason?? The coil works and I tryed a different one and same affect. The spark is different off of one coil then the other like almost a bit too much spark. I tryed new plug wires and the same thing. Its all wired up right. I put in new plugs gaped and tryed old ones. I have fuel pressure and all injectors read same voltage meaning they are opening. I even sprayed some starter in the intake nnd no difference so its getting fuel. Thought it might be flooded so i repeaditly took plugs out and cranked until dry plugs. No better and not flooded even with new plugs again. Tryed a new CAS and no difference. Messed with all different plug order and got it on the right one. It comes down to a wierd spark and maybe bad ecu to me. Anyone have an ecu I can try? Let me know what you people think. Thanks for the help.
Old 09-05-2006   #34
OK...
We found out that its not the ECU, Fuel(anything), Transtistor, Coil or CAS.
I brought over my ECU and my Nearly brand new transistor and nothing happend differently.
When we play with the wire on the CAS(either the + or -) the fuel pump runs(when key in on position) and the fan starts then shuts off. This is where I was confused. Why does the fan come on when we plug the CAS in? It goes for like a second then shuts off, almost like the relay clicked on and then shut off right away.
As for the spark, It looks a little weak and doesnt seem to fire very steady.
Someone help us out!!! Im getting pissed off and its not even my car.
Old 09-05-2006   #35
95talonracer
Finally Tuned...
Drives: Spyder GSX
Yes I agree if there is any help or ideas post and we can get another dsm back on the road.
Old 09-05-2006   #36
Have you checked the plug gap? Are you sure the CAS isn't off 180*?
Old 09-05-2006   #37
Plug gap was fine and the CAS is not 180 out(He tried that and that made it worse)
Old 09-05-2006   #38
Scrmegl
Brian
Scrmegl's Avatar
Danger Wheels Champion!
Drives: '98 TSI AWD
Send a message via MSN to Scrmegl
I thought I read before that if you invert the CAS you need to switch the 1 and 2 also the 3 and 4 plug wires. I know you said you tried all combos.
Was the fuel system and pump primed when testing the combos?
I may be way off or going over covered ground. Good luck.
A Body to G Body to F body to 2G DSM
Scrmegl is offline   Reply With Quote
Old 09-06-2006   #39
It is nothing fuel related, We got fuel into the cylinders and the fuel pressure was fine. We tried all combos of 4 and 1 wires switched with 2 and 3 wires.
Old 09-06-2006   #40
I would look at the plug wires and the wiring swap. After that try swapping coils.
