Old 09-14-2006   #21
Re: airfuel gauge
Being in the red doesn't matter much, if you aren't under high load and the car still manages to run. When you are too lean at low load the car just bucks or dies, it doesn't blow up. Under boost load, even well into the green is potentially very dangerous on a turbo DSM.
Old 09-14-2006   #22
Re: airfuel gauge
Word!
Old 09-14-2006   #23
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: airfuel gauge
sorry, I wasnt specific enough I guess. In the red under load. Also, "well into green" on a narrowband, like josh said, doesnt mean much. If its pegged on green it might tell you something, but again, a safety device, you should definitely use a wideband to tune your car first anyway. But yes, your a/f at full boost or WOT should definitely be in the green.
The scenarios I would say a narrowband helps in are:
-red all the time, even under load
-green all the time.
that's about it.
Style's automotive engineer
Old 09-14-2006   #24
Re: airfuel gauge
Red all the time = gauge broke, wired wrong or bad O2
Green all the time = gauge broke, wired wrong or bad O2
Old 09-14-2006   #25
s1ngletracker
Drives: A BMW
Re: airfuel gauge
lol, very possible, but not always true. I had green all the time once, turns out my fuel pressure was thru the roof. it saved me that time. I haven't had red all the time happen, but it was red under some load once, however I wouldnt have needed the gauge because like you said before it was bucking like crazy
Old 09-21-2006   #26
Elementality158
Elementality158's Avatar
Send a message via AIM to Elementality158
Re: airfuel gauge
Mine still isnt working. It wont show anything. Once in a while it will start working and then stop. And when i turn on the blinker, it blinks with it. When i turn the defrost on. Its always green. A little help please?
Elementality158 is offline   Reply With Quote
