Old 10-31-2006   #21
Re: boost controller
Joe P. is a great MBC, I used mine for years with zero problems.
Old 10-31-2006   #22
Originally Posted by 1slowdsm View Post
It's the one I bought from QPR a couple years back. It came off of Mike's car. And it's currently busted. Doesnt hold boost at all. (bad spring?)
Sorry, but that's funny. It must have been his super secret boost controller that he engineered from unobtainium.
Old 10-31-2006   #23
turboDSM
turboDSM's Avatar
Drives: tastefully modded BMW : )
turboDSM is offline   Reply With Quote
Old 10-31-2006   #24
^That routing leads to boost spike.
Old 11-01-2006   #25
turbo2086
turbo2086's Avatar
Send a message via MSN to turbo2086
^ He is right. To receive minimal boost spike, you should have the boost source coming from as close to the turbo as possible.
Ex. Using the little nipple on the stock 1g j pipe.
2004 Dodge SRT4. Bone Stock
2006 Toyota Sienna. Swagger Wagon
SOLD 1992 Plymouth Laser AWD. 13.4 @ 102 Stock tune and turbo.
turbo2086 is offline   Reply With Quote
Old 11-01-2006   #26
I ran up to 25 psi with the MBC coming off the turbo outlet elbow and it was rock-solid with no issues.
Old 11-01-2006   #27
Originally Posted by Jaei Sun View Post
What kind of pressure effects??
With any gas, temperature and pressure directly affect each other. By changing the temperature, you can change the pressure, and vice versa. Air in the intake manifold should always be the same, unless your intercooler is getting heat soaked. Therefore, your mbc will always have the same pressure for reference when trying to displace the ball/spring combo for a set boost pressure.
When you run the MBC sourced from an inlet pipe before the intercooler, there will different temperatures of air coming out of the turbo and your MBC will theoretically have it's ball/spring displaced as different volumes of air pass through it (since it is a pressure-based switch). This would result in different resulting pressures in the manifold (after the intake charge has passed through the intercooler).
With that being said, a lot of people run their MBC sourced from the turbo outlet w/ little or no variance in resulting boost pressure.
PV=nRT
ref: http://en.wikipedia.org/wiki/Gas_Laws
