Old 05-30-2007   #21
Re: Low Mileage stock bore Rod/Piston swap
I don't think anyone was asking if this is the best way to do it, just can it be done and will it last. Yes and if you're careful, yes.
Old 05-31-2007   #22
Yes it can work, I would get the rods/pistons balanced but thats just me, off to the parking lot to swap in rods and pistons quick befor work.
Old 05-31-2007   #23
So update, I guess you just cover the oil squirters with vacuum caps.
Old 05-31-2007   #24
just cover them up.
It does work just fine I have done it my talon and it has been going for over 20k when I put in the 95 pistions on the 1g rods.
Old 05-31-2007   #25
Mark, did you use a ball hone when you did this? If so, do you remember what type/size etc?
Old 06-01-2007   #26
I used a 3 stone hone I like them better than the ball ones
Old 06-01-2007   #27
I would just take the oil squirters off, its only 4 bolts and then you have no chance of bending them.
Old 06-01-2007   #28
unfortunally with just a ball-hone you will be hard pressed to get the optimum surface finish on the cylinder walls, not that most shops even care about that.
Eh, I'm sure it works well enough, and I'm sure if proper break in for the rings was done, I'm sure it'd be fine. Maybe not something you'd make 450hp with reliably. You just have to NOT be a dumbass.
Old 06-01-2007   #29
Any tips on what type of break in should be done after doing something like this? I'd think a startup and few miles of breakin, then oil change, then few hundred miles, then another oil change would do the trick, no?
Old 06-01-2007   #30
YiNYaNg
Hold Alt & press F4...LoL
YiNYaNg's Avatar
http://www.mototuneusa.com/break_in_secrets.htm
A bike engine builder but same applies for car engines
Originally Posted by ecoli
Some cars are so slow that even the cops can't tell they are racing.
http://www.myspace.com/kounpheng
YiNYaNg is offline   Reply With Quote
Old 06-01-2007   #31
Oh God, not that crap again.
Old 06-02-2007   #32
Haha, break it in like you stole it!
Old 06-02-2007   #33
v8klla
v8klla's Avatar
We have done this on one occasion at least as the customer was on an extreme budget. As stated previously this is not the best way to build a motor, but it does work. Assure that you cover the crank during the honing process, remove the oil squirters, watch for oil on the backside of the rod bearings, and clean the hell out of it afterwards and your results should be positive. Possible issues are increased oil consumption, cylinder taper, cylinder out of round, and compression issues based on finish quality of the cylinder wall and ring seating.
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
