Old 11-07-2007   #21
iceminion
iceminion's Avatar
Re: Galant VR4
the only problem I have is a clutch issue, which I could use some help with.
I can get into a couple gears only after adding an extension to the slave cylinder push rod (the extention is a 3/8ths socket)
I have a L4 competiton clutch with a new fidanza flywheel, I have bled the clutch system, I need to know a couple things before I continue.
what is the proper travel of the slave cylinder? in cm or mm
where does the clutch fork need to rest?
I am guessing that the clutch fork is bent, any suggestions?
building a 3000GT AWD Turbo.
Old 11-07-2007   #22
Re: Galant VR4
9.5:1 compression?
Old 11-07-2007   #23
iceminion
iceminion's Avatar
Re: Galant VR4
Thats what map tells me....http://www.maperformance.com/store/p...cat=402&page=1
Old 11-07-2007   #24
Re: Galant VR4
Is this an E85 or race gas only car?
Old 11-07-2007   #25
Re: Galant VR4
Congrats on running car.
Old 11-07-2007   #26
iceminion
iceminion's Avatar
Re: Galant VR4
e85 only, it is chipped for 780cc's for 92 octane, im just going to drop in my 880cc's and do the fine tuning with my SAFC,
I assume that I would blow my car up if I ran 92 octane?
Old 11-07-2007   #27
Re: Galant VR4
No, higher compression just limits the amount of boost you can run before you start knocking.
