Old 10-24-2007   #21
Re: finally getting the car tuned
The dyno logs everything and you can look it up at anytime, I will give one to your bro if you want. Dyno settings: 4wd Center Viscous, inertia set to 80, ramp rate of 120, all corrections off, straps on the back only with a strap to hold it back so it does not pull up on the dyno, no knock showed up, NGK BPR7es plugs @.028, E-85, and 24.5psi of boost.
Old 10-24-2007   #22
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
thanks john it's much appreciated
Old 10-24-2007   #23
3rd or 4th gear? Why wouldn't you want it to pull up into the dyno? That is how you get traction on a Dyno Dynamics.
Old 10-24-2007   #24
Here we go again. Here is a link to a post I made about the DD and why we use it the way we use it.
http://www.mitsustyle.com/forums/sho...=dyno+dynamics
Long story short for this thread, if the car pulls up on the rollers you have the weight of the car putting load onto the load cell also. This will make the power read higher then if the car did not pull up the rollers. We did some testing with my stock 1g and the car would make anywhere from 140awhp to 210awhp pending how the car was tied down and the ramp rate. Also we did some testing with my Honda and the settings in the computer, and it would range from 80 fwhp to 225,xxx.x fwhp that is not a typo. The graph screen can only show up to 30,000hp and the snap shot file can only show up to 99,999 hp but tractive effort can read up to 9,999,999 lbs, which the computer showed 1,xxx,xxx lbs of tractive effort for the Honda. As long as you set the cars up the same each time and you see gains/loses from tuning thats what matters, the end all number is just that, a number. Just like any measuring device, two people measure the same thing and you get 2 different numbers.
Time to go run my car again and let it pull up on the dyno and see what numbers we can get.
Old 10-24-2007   #25
I don't know how you would ever get traction on FWD cars without letting it pull up on the roller some, if you hold them back too much, the tires will spin.
Old 10-24-2007   #26
C'mon guys, let's keep the drama to the dyno day thread!
Old 10-24-2007   #27
Craig, when are you getting your car? We always check MPH vs RPM if we hear a car spin the tires or have the clutch slip, as long as the RPM is off the engine somehow it will show a straight line if the clutch/tires hold. This is a fun Q/A though.
Old 10-24-2007   #28
craig
wants to kick mark
craig's Avatar
got it like at 730
Old 10-25-2007   #29
So, is anyone not running E85?
Was that reving out to 8000? Time for an intake manifold. My wife's drops power like that too.
Old 10-25-2007   #30
Mine drops off pretty hard after 7k on top too. I am also on the stock intake manifold.
Old 10-25-2007   #31
craig
wants to kick mark
craig's Avatar
yeah i'm planning on getting a smim but gotta get the funds back up again first
Old 10-25-2007   #32
Ohh! Me! I'm not. But I want to. cheaper, more power, why not?
Old 10-26-2007   #33
LOL i got my intake manifold a LONG time ago, when magnus was having the Buy an intake mani, get a fuel rail free. That was last year, around this time actually. I love it though. Always wondered why everyone runs the stock manifold on these big turbos, i guess it just doesnt make sence to put a bottleneck right before the engine.
Old 10-26-2007   #34
craig
wants to kick mark
craig's Avatar
i agree but i just needed to get it tuned before it gets re-tuned this spring
Old 10-26-2007   #35
Are you drunk? One year ago is not a LONG time ago, its....only a year ago!
Old 10-27-2007   #36
I'm also on a stock IM. If Jet would just hurry up and make his! If he doesn't get it done soon, I'm going to slap something of my own togther with some scraps
Old 03-08-2008   #37
craig
wants to kick mark
craig's Avatar
my father and I just changed the car over to a 1gb talon rear. I like it so much better than the 1ga so yay me.
Old 03-08-2008   #38
95talontsi
nice mods I looking for more power as well GREAT JOB
95talontsi is offline   Reply With Quote
Old 03-08-2008   #39
Did you find the plugs you needed?
Old 03-08-2008   #40
craig
wants to kick mark
craig's Avatar
father did his thing and made the ones we have work.
