Old 05-06-2008   #21
Re: I need proof E85 works…and tips for setting it up.
Measuring octane is a lot different than measure the percent of alcohol in fuel. I have measured the ethannol content in E85 and normal pump gas using a pop bottle.
DSMs actually have a sensor on them for measuring octane, it's called a knock sensor.
Old 05-06-2008   #22
DSM_421
Lol, well how do you measure normal pump using a pop bottle?
Old 05-06-2008   #23
merkzu
The ethanol would rather mix with water than gasoline, so you can put water and gas in a bottle, shake it up and measure how much the water level increased. A lot of 92 has around 10% ethanol
merkzu is offline   Reply With Quote
Old 05-06-2008   #24
421, that sensor detects percentage of ethanol, not octane. In Minnesota that's 10% for all normal pump gas if I'm not mistaken.
Old 05-06-2008   #25
crazy_skier
A.E.K.Δ.B
crazy_skier's Avatar
Beer Dude 2 Champion!
Drives: 1994 Suburban
correction... the non-oxygenated is supposed to be ethanol free... but who knows if it really is.
Old 05-06-2008   #26
The non-oxy should be ethanol free and it usually more knock/detonation prone on boosted cars because of it.
Old 05-06-2008   #27
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
That and most places don't move it enough to keep its octane rating that high. just sits there.
This thread is interesting because I am going to be switching pretty soon to E85.
I am hoping I can find a flex fuel sensor for my car so I can run whatever I want (premium or E85). However they are kind of expensive.
Old 05-07-2008   #28
MitsuChick
Guest
Tournaments Won: 6
Posts: n/a
Does anyone know how much 111 is these days? Like at Bobbie and Steve's?
Old 05-07-2008   #29
That stuff is crap, not worth the money. I used to get 100 octane unleaded from a self-service pump in Dayton, which was pretty good at $4.25/gallon back in the day. Other than that, C16 is your best option.
