10-20-2008
#1
Re: Starts like ass, sputters and runs rich
A bad/leaking FPR would cause a lack of fuel I would imagine.
10-20-2008
#2
Drives: 2022 Hyundai Palisade
what about the possibility of it just not opening quite enough and causing a blockage?
10-20-2008
#3
The chances of that seem pretty slim, but if you can get a spare there is no harm in trying it.
10-21-2008
#4
i had a 2g na, try youre cam angle sensor, i had the most problems with that. my car would run but it kinda had the same symptoms with the rpm's
FASTER AND FASTER! TILL THE FEAR OF DEATH IS OVER COME BY THE THRILL OF SPEED!!!
10-21-2008
#5
I pulled the vacuum line off of my fuel pressure regulator and tiny spits of fuel came out and a co-worker of mine said that's a sure indication that it is junk.
10-21-2008
#6
Fuel coming out of the vaccuum port on the FPR indicates a torn diaphram which means the fuel coming out of the vaccuum port is going into your intake manifold. Hence; running too rich.
10-21-2008
#7
Problem solved
10-21-2008
#8
and to probably answer my question in a dumb way.. The torn diaphragm is from drying out for the almost 2 years it sat with no start and no lubrication?
10-21-2008
#9
Very possible.
10-21-2008
#10
One final thing before I say enough with this thread... I must have a vacuum leak somewhere that is causing my idle to be around 1200-1300rpm. and my question is that, does it matter which vacuum line I have that could be causing this or is it a specific hose?
10-22-2008
#11
Drives: 1992 Eagle Talon TSi Awd
Check all of the lines that attach to the throttle body. Make sure that they are connected to the appropriate emissions controls.
10-22-2008
#12
Back to the beginning... I replaced the FPR and it ran last night and now trying to start it this morning it will not start at all. It gives a shake like it got its fuel then I get nothing at all and it sits and cranks, that's all.
10-22-2008
#13
Are you sure you pressed the fpr in correctly?
It is very easy to have it not seal.
Have you replaced the fuel filter already?
10-22-2008
#14
It was a auto get over it
If i were you i would just drain the tank, put small amount of gas in, seafoam it, then fill with good gas.
10-22-2008
#15
waY the filter is new... I'm not draining the tank yet. How exactly are you supposed to press them in other than pressing it in?
10-22-2008
#16
I just got it started which I pulled the vacuum line off which idk if that made any difference or not but the rpm's are pretty good now without stuttering but I am noticing once difference in the way it runs when it gets to 4000rpm.
Compared to the old FPR, when I reached 4000 it sputtered a lot until it got warmed up and then I would be able to reach higher rpm's. Now Instead of stuttering it seams to load up instead. Now I haven't taken it for a ride yet which I am about to go do. But If anyone has any ideas to this then good.
The other thing I can think of as to why it wont start good is maybe because of a lot of air in the fuel rail since I opened one end? Also does it make a difference as to what car it came off of? Like a from a turbo model FPR on an N/A setup? maybe there is a difference in regulating pressure?
10-22-2008
#17
Screw the too much air idea considering I took it for a ride to get things of need and if it sits for 5 min compared to cold I get the same result.
It sounds like it wants to start then I get nothing. It starts but then slowly dies. Finally starts but is very clunky but eventually clears out. When in first gear (when cold) it still is very sensitive per say if u press the gas down it lunges then clears back to normal. It still hesitates randomly when driving.
Canister of gas and a match?
10-22-2008
#18
I'd definitely stop driving it. You could lean out and blow it up.
I'm starting to lean towards a clogged fuel rail, but even that is highly unlikely.
10-22-2008
#19
I need a car to drive. If I can get a pc quick to setup my data logger I could monitor it.
10-26-2008
#20
Is there anyone that lives close to Eagan, and if not anywhere where I could bring my car to? I am looking for someone that has a vacuum gauge and a compression tester so I can get these 2 things out of the way and maybe figure out my problem as to whats going on with my car and why it's still not running right.
I am considering replacing related fuel parts to maybe get the problem solved. But not until I get these 2 test out of the way so I'm not wasting money.
