Old 04-10-2009   #21
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Re: Will my fricken' luck ever change?
I wouldn't mind the lag at all, if It would rev. That's just it. I really dunno what to do. Stroker motor, downgrade the turbo. But, even if I do that, I'd still want it to rev. IF it was valvetrain, we all would think that it would not wanna rev consistantly. But, it CONSISTANTLY stops at fricken 7950ish, and then the fuel keeps going, dumping it all in, backfiring, and sounds like a fricken subaru! ARG!
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 04-10-2009   #22
Swifty1638
Swifty1638's Avatar
-double post, stupid comps-
Black 1GB Mafia #1
I wanna go fast.
Old 04-10-2009   #23
wants to be sideways...
123abc's Avatar
Drives: Loud cars
-A. Swift
To me it sounds like a spark issue. But what do I know. lol
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 04-10-2009   #24
Get a smaller turbo for sure. Make awesome power from 4500-8 and be happy. Who cares if you cant get that extra 500 rpm?
Old 04-10-2009   #25
GSXMatt
You can't buy my Evo.
GSXMatt's Avatar
Drives: 03Evo,11Altima
Send a message via AIM to GSXMatt
Swifty does!
99 GSX- Sold
03 Evo- More than stock.
-ATC Productions-
is dead.
I hate Mitsubishi.
GSXMatt is offline   Reply With Quote
Old 04-10-2009   #26
I am looking into a perhaps "smaller" turbo setup..most likely the 6262, but I dunno.
I've tried John's AEM EMS, I've tried different maps, I've tried brand new coils, eliminating the MSD, AND going back to a stock ignition, ALL TO NO AVAIL! I DO NOT KNOW what the F is wrong with this damn car, but the money i've spent in chasing this F-in issue is beyond redonculous.
-A. Swift
The problem is you have systematically elimated problems and once you've checked it off you haven't went back and rechecked it.
The cam degreeing was off, was it hurting power? Who knows, compare the poweband charts I guess.
The inproper grounding was bad for the car. Was it the only problem? Obviously not...but I guarantee the car needs its grounds.
If the wiring was the problem the entire time it could of masked a bad cop setup as well. Were the ignition coils you swapped in good? I know the map and aems have been swapped also. I know that one time we found 1 coil not making contact all the way with the plug when street tuning.
Have the ignition signal wires been traced from the AEM to the msd? How about to the coils?
The engine is in 100% perfect health? Then it is a wiring or electrical (ignition) issue.
Old 04-10-2009   #27
Just out of curiosity, what plugs and gap are you running? We ran into some miss-firing on my car also. I was running stock BPR6's gapped at .020. Swapped in some 7's gapped at .020 and the issue was gone.
Another dumb question, but if you turn the boost to the minimum you can run, do you still have miss-firing issues at higher RPM's? As I'm sure you're well aware of, the more boost you run, the more your chances of running into spark related issues.
Great numbers though. I think you have a TON of more power in that thing if you can get it all worked out. Like brownman said, 500 on DB's dyno is nothing to laugh at. We all know that, no need to tell us what it'd make on a DynoJet. I'm sure you'd walk me, considering I have hardly any weight reduction done.
What tires are you running btw? I haven't gotten squirrelly in 3rd yet, just 1st and 2nd. I'm on some 235/45/17 HTRZ3's, and they seem to be gripping quite well.
Old 04-10-2009   #28
Car hits a brick wall at any boost. It did the same at 20psi when I was messing with it last fall.
Old 04-10-2009   #29
Swifty1638
Swifty1638's Avatar
Thanks guys for your input. I wanna say again it's no fault of anyone here, or am I blaming everyone..I'm just disappointed in power vs/ boost, and the revving issues.
Brandon, we swapped my plugs once they got bad on the dyno, with new ones..bpr7es, gapped to I BELIEVE .020? (shane?)
Boost at a minimum still won't allow it to rev past that 7950..it hits a wall, sounds/feels like it's a hard, rather rapid 2-step cut, and falls on it's face. Gas planted to the floor, it WILL NOT rev past. But, free-reving, it will all the way. Yes, we checked and double checked all rev limiters, and the ignition setup, like hte MSD box and such.
Tires are def. an issue..3rd..and If I remember right 4th too last night(cooler out?). They are Riken raptor ZR's..225/50/16. The rims are 16x8 I'm pretty sure (maybe 16x 8.5) and I wanna go to a wider tire setup..perhaps something in a 245/255 variant.
-A. Swift
Black 1GB Mafia #1
I wanna go fast.
Old 04-10-2009   #30
x-pride
x-pride's Avatar
Brandon and you are making me jealous. Can't wait to get me car on the dyno again. This time with E-85 instead of pump.
Old 04-10-2009   #31
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
I say run 'em!!!!! with video.
'04 Honda Ricer: stock
Old 04-10-2009   #32
Swifty1638
Swifty1638's Avatar
Pretty sure he'd wax my ass, so it's not even funny. brandon has that thing called "awesome poewrband..with power!" not only does he make more, but he makes more, with more to use.
-A. Swift
Black 1GB Mafia #1
I wanna go fast.
Old 04-10-2009   #33
Coming to hooters tonight?
Old 04-10-2009   #34
-A. Swift
If free revving works....what if you back off to like 80% throttle @ 8k....?
Old 04-10-2009   #35
Swifty1638
Swifty1638's Avatar
still hits wall..any kinda load it hates life.
And, hooters MAYBE. But, I assure you..you'll win. You get better traction, more power, powerband, and my car is hitting some fuel issues up higher rpms', say if I start out at 40 in 2nd or 3rd.. it doesn't like WOT..then clears, then goes..then hits the rev limiter shane set.
-A. Swift
Black 1GB Mafia #1
I wanna go fast.
Old 04-10-2009   #36
To bad you live in Savage. Can't swing by anymore to look issues quickly.
Old 04-10-2009   #37
Swifty1638
Swifty1638's Avatar
lol i'm closer to your work then you are..lol
-A. Swift
Black 1GB Mafia #1
I wanna go fast.
Old 04-10-2009   #38
santa
Boost Spike
santa's Avatar
You should have never changed your exhaust housingnto that .82?? I still have that .68 at exhaust housing on my ride. It spools very quick for a bigger turbo and makes great power. I vote to go back to the .68ar housing. :-)
Old 04-10-2009   #39
Swifty1638
Swifty1638's Avatar
I have a divided .70 housing, with the divided manifold. Before it was an undivided .58.
-A. Swift
Black 1GB Mafia #1
I wanna go fast.
Old 04-10-2009   #40
santa
Boost Spike
santa's Avatar
Ahh my bad I thought you had the big housing. How come it's so laggy??
