Old 05-19-2009   #21
Re: Garage Mod #4: let there be light!
Ya, the garage is detached, and it is an oversized 2 stall. I don't have gas run out there, but I do have a pretty good electric run out there. I need to figure out how to rewire the fuse box for a 240V circuit and prolly go with one like peter linked to. My neighbors actually have one they inherited from her dad, it looks a tad on the small side though. Still, it could work as an initial install, then upgrade to a bigger one later on
Anyone know how to wire 240? I have all the beer and food you can stuff yourself with.
Old 05-19-2009   #22
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
How new is the wiring to the garage?
Your garage should have 240 standard unless it is really old.
You need 2 hots, a neutral, and ground.
Do you have breakers or fuses?
Originally Posted by shoutbox
Old 05-20-2009   #23
Breakers. There's like 6 or so in a small box. There is some blank spots, not sure if I can use those or not.
Old 05-20-2009   #24
you should ask and offer beer to my dad. he has done in a few times. he added 240 at craigs for the air compressor
Old 05-20-2009   #25
Does he like asian? How about beer + dinner at that Peony's place
Old 05-20-2009   #26
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Its very simple if you have open spaces... If its breakers, 9 times out of 10 you have 240v at the main. Get a roll of wire, 3 or 4 strand, usually go with 10/3 or 8/3 depending on amps you plan to run through it. You buy a 2 pole breaker (whatever amperage you need), pull the cover off, place breaker on the board, hook black wire (hot) to one pole and red wire (hot) to the other pole on the same breaker. White (neutral)/Green (ground)/Copper (ground) all go to the ground block.
If you have Black, White, Green wires... Use Black and White as your 2 hots and Green/Copper as ground/neutral.
I'm sure you can find a diagram on google images. Very simple.
Old 08-08-2012   #27
Irych
Drives: mazda626
If everyone is searching out bright lights then I am willing to prefer nice led lights. They are bright than other lights along very low operating cost.
Irych is offline   Reply With Quote
Old 08-08-2012   #28
viridionplague
only 3 years behind the times. lol
Old 08-08-2012   #29
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Dude, you don't need 50 quality posts to see the for sale threads. This is not MNSC. haha
