Old 05-31-2009   #21
Archertsi
Archertsi's Avatar
Drives: 1995 talon tsi
Re: Brembo stopperz
I thought it all looked like sex, until the gold paint. Don't get my wrong though cause it's still awsome. But if there going on a red 2g and black with a red lip rims. It doesn't seem like it would match you're color scheme very well.
Well the rims will not be black with a red lip, just one dark color (diamond black,gun black or gloss black) They arent supposed to match, (you dont see them match any STi or Nissan) this is a factory Brembo color, that's why I chose the color. So they look like factory Brembo brakes. Plus I think they will stand out more behind a dark wheel.
wow, very impressive. You should mass produce those brackets.
The problem there is I had to machine the backside of the caliper mounting tabs becaues these brackets bolt onto the other side. Each knuckle ends up being machined differentley because you never know how much you have to take off until it is totally flat. So each bracket is made to each specific knuckle. People would have to send in thier knuckles to be machines and brackets made to them.
The liabilities behind making these and machining someones knuckle could be huge. I am no engineer so who knows what could happen though I am sure mine will be fine.
For me to make up for the time it takes to make this kit and for the parts (front/rear calipers/rotors/lines/brackets) I figure this kit would cost $2000-$2500 and at that rate there are better kits out there for less money.
Horsepower costs money, how fast can you afford to go?
@BloodSweatMotorwerks
Archertsi is offline   Reply With Quote
Old 05-31-2009   #22
Re: Brembo stopperz
You had to machine the knuckle? What was machined?
Old 05-31-2009   #23
Archertsi
Archertsi's Avatar
Re: Brembo stopperz
Eh, I'd say black would look cool, red brembo stickers.
So do you think that tiny hub centric ring might get damaged or melt or something?
Nope, if you think about it, when you use it on wheels, it is touching the rotor anyway. I guess in my mind if they are on the front or back side of the rotor shouldnt matter.
I guess with track time they could be exposed to significant heat, but dust boots/pistons seals dont melt. The wheel/wheel bearing also absorbs heat. We will see, I think they will be fine but if they are not, I will make a set out of aluminum.
Old 05-31-2009   #24
Archertsi
Archertsi's Avatar
Re: Brembo stopperz
You can see it here, the shiny metal on the caliper mounting tabs, stock brakes bolt onto the other side. The back side that you see here normally has steel casting flash around the bolt hole. I had to machine them flat so the aluminum bracket could bolt up on this side instead because the rotor has so much offset to get the caliper away from the wheel spokes.
Old 05-31-2009   #25
Re: Brembo stopperz
Oooooo, I see. I didn't realize that bolt on from the other side.
Is there a reason you didn't put the head of the bolt on the aluminum side of the brackets?
Old 05-31-2009   #26
Re: Brembo stopperz
Yeah, personally, I would have kept the brakes painted how they were/left the viper sticker on. Looks unique that way.
Old 05-31-2009   #27
dedlewamp
Drives: 4G63
Re: Brembo stopperz
Maybe this is a stupid question but, won't the rotor move a little bit since the wheel studs are smaller than the holes? Eventually won't all that banging around cause issues?
dedlewamp is offline   Reply With Quote
Old 05-31-2009   #28
Re: Brembo stopperz
Brake rotors always have play and are able to move around until the wheel is torqued on.
Old 05-31-2009   #29
Re: Brembo stopperz
Wow this looks awesome, nice project!
Old 05-31-2009   #30
Archertsi
Archertsi's Avatar
Re: Brembo stopperz
Im not sure I understand what you mean, are you talking about the bolt that holds the bracket to the knuckle or the stud that holds the caliper to the bracket?
Exactly, the rotor is centered, once the wheel is torqued on the rotor wont be able to move. The centering ring keeps it concentric so it doesnt matter where it is in relation to the studs when you put the wheel on
Thank you, it's allot of work.
Old 05-31-2009   #31
Re: Brembo stopperz
The bolt that holds the bracket to the knuckle. Uh nevermind. I'm thinking the KNUCKLE has threaded holes, but it doesn't. And you threaded the bracket. So nevermind.
Old 05-31-2009   #32
95tsi
95tsi's Avatar
Drives: a pos
Re: Brembo stopperz
Looks good. I like the idea of ditching the viper emblem. Your not drive a shop car so no need to have them labeled that way. I'll have to forward this on to Mark, he is working on another Syclone project...
Old 06-09-2009   #33
Archertsi
Archertsi's Avatar
Re: Brembo stopperz
Got the calipers wet sanded and buffed with the decals on. Kinda thinking maybe I should switch to red decals like the STi's have. Idk, I can always peel them off and switch them later.
Old 06-10-2009   #34
Re: Brembo stopperz
I like the gold/black combo
Old 06-10-2009   #35
Re: Brembo stopperz
They look really good!
Old 06-10-2009   #36
Re: Brembo stopperz
Awesome, looks very nice. Makes me want to repaint my Fadedbros.
Old 06-10-2009   #37
Re: Brembo stopperz
Looks great. I was planning on doing a custom BBK on mine, then lost interest. Having a bridgeport has got to be nice, aluminum is a real pain to work with.
