Old 09-15-2009   #21
Powers
Powers's Avatar
Drives: 93 mx6!
Send a message via MSN to Powers Send a message via Skype™ to Powers
Re: wont start
umm probably just have to rent one and figure out how to do it myself. i have not put the exhaust on so there is no o2 sensors hooked up would that do anything?
Powers is offline   Reply With Quote
Old 09-15-2009   #22
deadeye
deadeye's Avatar
Drives: 95 TSi AWD POS
Re: wont start
It shouldn't make it not start. It will just run like crap when it does. If your in doubt plug em in and see if it helps.
The code reader is cake. All you gotta do is push a button and it does the rest for you. Thats gonna be your best bet at this point.
deadeye is offline   Reply With Quote
Old 09-15-2009   #23
twack
It was a auto get over it
twack's Avatar
Re: wont start
with a nice downpayment autozone might rent theirs
Old 09-15-2009   #24
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: wont start
My o2 sensor is non existant at the moment and my car runs fine. Don't think that would cause a no start.
Old 09-15-2009   #25
Powers
Powers's Avatar
Drives: 93 mx6!
Re: wont start
ok i didnt think it would really do anything like not make it fire at all
Old 09-15-2009   #26
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: wont start
Check and make sure the ground wire is connected that plugs together by the thermostat housing. It is a single black wire with i think a yellow stripe and it plugs into another single wire of the same. I forgot to do that and it had nothing.
Amsoil Dealer
Old 09-15-2009   #27
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: wont start
Hmm... You replaced the cam sensor behind the intake cam? Did you make sure to put the correct cam gear back on after you did this? No reason to take the exhaust cam off but could the intake cam have gotten switched with a different one or even the exhaust cam if both gears were taking off?
Originally Posted by shoutbox
Old 09-15-2009   #28
Powers
Powers's Avatar
Drives: 93 mx6!
Re: wont start
They are in the correct possition I had them marked
Old 09-15-2009   #29
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: wont start
Where is the car located? Did Twack swap the motor or just do the timing?
Old 09-15-2009   #30
Powers
Powers's Avatar
Drives: 93 mx6!
Re: wont start
Car is by Mankato and be helped bolt it in but me and a friend hooked everything up so honestly I'm sure it's some hooked up wrong or not at all
Old 09-16-2009   #31
twack
twack's Avatar
Re: wont start
ya i came out and put the timing belt on the engine while it was out of the car. I had some extra time so i also got it on the motor mounts. Alliance i know you had a way of towing a couple weeks ago could you tow it to get that code checked?
Old 09-16-2009   #32
Powers
Powers's Avatar
Drives: 93 mx6!
Re: wont start
this weekend i got a friend that works at advance auto parts he is gonna bring one over and we are gonna check it
Old 09-16-2009   #33
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: wont start
You never answered my question. Did you check to see if that one single black wire was plugged in? If not, that will make it not start.
Amsoil Dealer
Old 09-16-2009   #34
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: wont start
That single black wire with yellow stripe should be the starter wire for the ignition. That wire would make it so the car wouldnt even turn over... IIRC
Old 09-16-2009   #35
Powers
Powers's Avatar
Drives: 93 mx6!
Re: wont start
Well the car turns over so the ground is fine
Old 09-17-2009   #36
Powers
Powers's Avatar
Drives: 93 mx6!
Re: wont start
ok so i cant figure this crap out so if someone would come help me out that would be awesome im sure we can work something out if anyone has some open time on sunday and would want to come help that would be awesome so let me know
Old 09-17-2009   #37
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: wont start
No this is a different one.
Amsoil Dealer
Old 09-18-2009   #38
twack
twack's Avatar
Re: wont start
to help whoever comes out you should get that code read first so they dont drive out there for nothing
Old 09-18-2009   #39
Powers
Powers's Avatar
Drives: 93 mx6!
Re: wont start
can do ill get that tonight
Old 09-18-2009   #40
TurboDomestics
TurboDomestics's Avatar
Re: wont start
Have you ever checked the ECT sensor (Engine Coolant Temp), when they go bad they give a ridiculous temp reading and the ecu doesnt know what to do. Ive had a few of those go bad causing many a headache.
4G63 0, Charlie 3
