Old 11-27-2009   #21
Re: The Spazmobile
Primo has fixed 2g strut tower rust before, btw.
Rust is taken care of, thanks to Mark.
you fail lol
Old 11-27-2009   #22
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: The Spazmobile
^ LOL.
Yeah, I'm pretty sure the slow boosting is partially due to an exhaust leak I can't seem to get rid of. One of the bolts from the o2 housing to the turbo keeps backing out, I'll get that taken care of again this weekend and see how much that helps.
It's not so much that response is actually decreased, but audibly it takes longer for the piping to fully charge, I'm not really spooling any later. I haven't done an official leak test, but all the ones we heard during testing we fixed, so if it's a leak, it's relatively minor.
Originally Posted by Trogdor
Old 12-01-2009   #23
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: The Spazmobile
O2 housing being loose shouldn't really cause slow boosting.
Style's automotive engineer
Old 12-01-2009   #24
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Re: The Spazmobile
Originally Posted by craig View Post
looking good still slower than a mini though....
LOL.... i need to get modding ours...
Old 12-01-2009   #25
Re: The Spazmobile
Eh, if it's anything like my car, when the down pipe came loose (not off) it wouldn't spool as fast and didn't make much boost. At first I started cranking the boost controller up, but it did nothing.
Old 12-01-2009   #26
redleader36
redleader36's Avatar
Drives: 1995 Eagle Talon TSI AWD
Re: The Spazmobile
The real test is going to be Marshalltown next season, I'm hoping to finally be able to beat Matt's Civic.
Just remember, I got new tires and new suspension too! :P
Anyway, looking good!
redleader36 is offline   Reply With Quote
Old 12-02-2009   #27
s1ngletracker
Drives: A BMW
Re: The Spazmobile
I suppose it could create a lot of exhaust turbulance which would hurt performance... but I sorta doubt it. More likely it is causing the knock sensor to register knock and pull timing...
Old 12-03-2009   #28
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: The Spazmobile
You know what? I think you're right.
But I have another question now... how the fuck does this even happen?
The bolt was fine when I put the heat shield on after the o2 housing came loose a few months back...
Anyway, vice grips are a no-go, was trying for 10 minutes, wouldn't budge, is my only option at this point dropping the turbo? I have spare studs, I just need to get this fucker out.
Old 12-03-2009   #29
Re: The Spazmobile
Damn that sucks. Id get rid of those studs anyway and go only bolts. Alot easier to deal with.
The car is shaping up though!
Old 12-03-2009   #30
Re: The Spazmobile
Car looks nice dude, keep up the good work.
Old 12-03-2009   #31
twack
It was a auto get over it
twack's Avatar
Re: The Spazmobile
depeding on how much wiggle rom you have. you could remove the turbo band, the 3 other mani bolts, and the exhaust and just remove the hotside of the turbo. that way you can try and leave the lines
Old 12-03-2009   #32
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: The Spazmobile
Actually, that was one of the bolts. I fixed that in my post.
I'm going to see about having a nut welded to the top of it, thoughts on that?
Old 12-03-2009   #33
s1ngletracker
Drives: A BMW
Re: The Spazmobile
welding a nut could work, methinks
Old 12-03-2009   #34
Re: The Spazmobile
Do it right.... Get it removed and get rid of those studs.
Old 12-03-2009   #35
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: The Spazmobile
Do you recommend anything specific to replace them with?
Old 12-03-2009   #36
Re: The Spazmobile
take it out and all bolts
I have some good bolts for turbo's I can get you a set just stop by
Old 12-03-2009   #37
deadeye
deadeye's Avatar
Drives: 95 TSi AWD POS
Re: The Spazmobile
A Irwin bolt out would probably get that out without having to drop the turbo. Otherwise welding a nut on would do it.
it's alive!!!
deadeye is offline   Reply With Quote
Old 12-03-2009   #38
Re: The Spazmobile
Brand new OEM bolts and some high heat treated lock washers, thats why I used on my 1g back in the day, never had an issue.
Old 12-03-2009   #39
Re: The Spazmobile
Same thing happened when I upgraded to a t28, for some reason the top broke off. Couldn't get it out with it in the car, but it was easy to get out with the turbo in my hands.
Go with OEM turbo bolts, should be the same as evo ones. I think they are about $5 apiece new but worth it over hardware store stuff.
Old 12-03-2009   #40
Re: The Spazmobile
Yup, put on new bolts and you won't have any problems.
