Old 12-29-2009   #21
Re: Help!!!
If your oil pressure light came on, you have issues. Save yourself the trouble of a compression test.
Drain the oil. Metal chunks=your engine is done. No metal chunks, change the oil, as the oil light comes on when its very low oil pressure. Then proceed to try to turn the engine over for a compression test.
Anything else disconnected? Does the engine crank over strongly? Any noises when cranking?
Very good chance you destroyed the lower end, reason it doesn't start is a munched crankshaft sensor.
Old 12-30-2009   #22
Powers
Powers's Avatar
Drives: 93 mx6!
Send a message via MSN to Powers Send a message via Skype™ to Powers
Re: Help!!!
ok so oil was clean but when i crank it over the cam gears dont move. the harmonic balancer does though
Powers is offline   Reply With Quote
Old 12-30-2009   #23
twack
It was a auto get over it
twack's Avatar
Re: Help!!!
goodbye timing belt
Old 12-30-2009   #24
talonite
talonite's Avatar
Drives: 1997 Eagle Talon TSI
Re: Help!!!
x2 ^ and if that went then yes your valves are probably toast
talonite is offline   Reply With Quote
Old 12-30-2009   #25
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: Help!!!
Prob take a look at your timing marks. Might have slipped.
Old 12-30-2009   #26
Powers
Powers's Avatar
Drives: 93 mx6!
Re: Help!!!
well i talked to twack today and i have decided since i leave sunday to finish basic and ait that i wanna do a 6 bolt swap and build the motor when i get back so if twack will help since he nows this motor like no other i can do it right
