Old 01-01-2010   #21
Twenty8
Drives: 95 GS w/ Turbo
Re: New and need some serious help
so i contacted brookdale mitsu to just get a full overlook of the car and just get everything checked out. I currently dont drive it at all because my parents are so scared to let me drive it. The mechanic just sounded like he just didnt like the whole idea of a modded car and so i just think he really didnt have a clue. i currently have a pressure gauge in there and it does work and it kind of seems like i may be running at about a 10 on the gauge but i dont watch it everytime i shift. Im really hoping its just the coils cause that is way less then we were told.
Twenty8 is offline   Reply With Quote
Old 01-01-2010   #22
CarPsyco84
CarPsyco84's Avatar
Run it till she blows lol. Welcome to the site, I'm sure someone on here has some stock 2g springs kicking around some where.
-When in doubt, Moar RPM.
Old 01-01-2010   #23
twack
It was a auto get over it
twack's Avatar
Again brookdale is not the place you want to take it, they know nothing about cars with aftermarket tunning and turbo kits. You need to take it to MAP or DB. besides if you take it to a dealership it will be the most expensive place on earth to be, and they wont even know what they are doing
edit: if your running 10 psi on a 420a you might want to try and get that down to 7 or 8 until you know whats going on so you dont blow shit up, and make yourself mad
Old 01-01-2010   #24
Do not go to Brookdale, this car is modified and they will not know what they are looking at, just as your mechanic friend didn't know what he was talking about. It needs to be seen by a mechanic at a local speed shop, preferably DB Performance or MAPerformance, find their info in our sponsor sections.
Once they see the car then come back to us with more information. But until then we aren't of much help for you unless we could see the car for ourselves.
Old 01-01-2010   #25
Ihearrtdsm
Hello Panduh
Ihearrtdsm's Avatar
Tic Tac Toe Champion!
If he is running a Hahn kit, he is running 5 or 8 psi.
Old 01-01-2010   #26
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
2gnt.com or jungy on here can help you the most to learn more about what you have. Are they still doing the 8 injector setup on these cars or has that new ecu thing came out yet? Or is hahn kit still use the fmu or whatever?
Old 01-01-2010   #27
Twenty8
Im actually going to MAPreformance now to hopefully figure everything out. thanks everyone for your help cause i need it.
Old 01-01-2010   #28
TurboDomestics
TurboDomestics's Avatar
If you decide you need some new springs Ive got a set of stock struts and springs for the rear. They are yours free if you want them
4G63 0, Charlie 3
Old 01-01-2010   #29
Twenty8
Hell yeah! I just gotta get my dad to let me fix everything and if its free i'm sure he'll let me.
Old 01-02-2010   #30
cmspaz
Walls need hugs too
cmspaz's Avatar
MAP has discounted labor rates this time of year. Not sure what they usually are, but I'd guess they're currently around $70-75/hr based on what I'm getting charged as we speak.
Originally Posted by Trogdor
Old 01-02-2010   #31
mlomker
*Resting In Peace*
mlomker's Avatar
That's interesting. The performance shops are opposite of regular garages--most shops are much busier during cold weather.
That works for me, I've got stuff to get done.
Old 01-16-2010   #32
Twenty8
So DB told me if i get it there they will look at it for free which is a plus and i have a friend who wants to buy the turbo and will pay to get it taken out if he can have it so that's another plus. I have been working on the inside of the car now and notice that i have 2 fuses missing and i dont have the cap for my fuse box so that's kind of a problem. If anyone has a 95 eclipse that they could send me a picture of that would be great. Again thanks alot you guys really helped me out
Old 01-16-2010   #33
twack
twack's Avatar
If i were you i would keep the turbo and just do any matinence it needs. The 420a engine has trouble on hills haha i should know i had one. terrible. terrible. That turbo should make it a car thats fun to drive.
Old 01-16-2010   #34
Twenty8
See the only reason i was gunna get it taken out was because i thought i couldn't run boost through the engine because that's what i was told. I guess i just gotta bring it in and get all of my facts straight
Old 01-16-2010   #35
Twenty8
I also need to know if the power steering has seized if i can get it working again. The guy told me they took it off for better control but it doesnt even move
Old 01-16-2010   #36
trunks11
trunks11's Avatar
Drives: like an old lady 458/1000
You can ran boost through your engine just not too much because it's not originally made for it. You can turbo any car, it's just a matter of destroying it at too high of a power level. The cars turboed from the factory (4g63) have stronger rods and pistons designed for boost. Your engine (420a) was not designed for a turbo so has weaker internal components.
Your power steering was deleted so there's no pump or belt I presume? You'll need to bolt it back on and connect it to the hoses to get back power steer.
Seriously, get on dsmtuners and 2gnt and just start reading. That's how I got started and I'm still learning all the time.
Edit: You can't turn the pump pulley or the steering wheel at all?
trunks11 is offline   Reply With Quote
Old 01-16-2010   #37
CarPsyco84
CarPsyco84's Avatar
Make sure its not locked from the column lock when you pull the key out, otherwise if the pump is taken out, you gotta have some muscles to turn the steering wheel cause of the no power assist. If you want the power steering back, I'm sure someone on here has a power steering pump around they would let go for cheap,
Old 01-17-2010   #38
Can't someone just meet up with this kid and answer his questions and point some stuff out? Where are you located?
Old 01-17-2010   #39
Ihearrtdsm
Hello Panduh
Ihearrtdsm's Avatar
I'm not sure if the Hahn kit has you remove you ps so you can fit a down pipe, might be the reason why he doesn't have it.
Old 01-18-2010   #40
Twenty8
I'm located in Woodbury.
