Old 01-27-2010   #21
Re: 1991 talon 500 hp project
If u look into my build that is what will give you your goal
Not that everything in my build is nessasary.. my tune was on major boost leaks and I'm going to get a retune this spring and shooting for 500 awhp
You BETTER make over 500 on THAT dyno....
Old 01-27-2010   #22
jrohner
jrohner's Avatar
I don't think there's anything that magical about Curt Browns 499hp 16G setup. He had basically EVERYTHING for supporting mods, and I think he was running like 12.5:1 compression or something crazy. I still think it was kind of odd having peak torque up at 5-5500, and much lower than the hp. My torque was about 120 higher at 4 grand.
It can be hard to compare one dyno to the next. Plus my dynochart from MAP shows SAE correction, not STD. I've done some quick checking and everything was basically showing a 2.6% advantage using STD over SAE. Now I also saw someone who got a 4.9% difference between the two.
Old 01-27-2010   #23
Tachyon
Tachyon's Avatar
Drives: Icarus
Originally Posted by Pushit2.0 View Post
Based on the Curt Brown dyno graph he was not at MBT for some reason, there was a little more in that tune, but I doubt that would equal more peak HP, but more torque for sure.
I am thinking that the cams have a very late IVC which lowers the overall dynamic compression of his pistons, thus resulting in more airflow at the cost of spool and MBT. I was going to say, didn't Jrohner make around 430 AWTQ (on the omgjet) with his 16g setup?
-Sebastian Vettel
Old 01-27-2010   #24
way2fastalon
IS Broken :-/
way2fastalon's Avatar
here is the turbo im getting of my buddy's 420a
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 01-27-2010   #25
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Well If I do it will be at a dyno day because I will be going to shane for my new tune.
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 01-27-2010   #26
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Attachment 9621
Ahhhhh... You know that turbo won't bolt up to your car right??? Get a turbo meant for a turbo dsm.
7/25/09
Old 01-27-2010   #27
Nice color 1G.
One thing I wanted to mention was not to waste your money on upgraded fuel lines. Stock 1G lines go a long way. An upgraded feed-line may be appropriate, but other than that, unneccessary.
Old 01-28-2010   #28
way2fastalon
IS Broken :-/
how will it not Fit ?
+more mods to list
Old 01-28-2010   #29
It looks like that turbo is welded to the manifold, and a turbo setup for a 420A won't bolt on to a 4g63 unless it's a t3 turbo, and you'll need a t3 manifold for a 4g63 to even get that to bolt on.
Old 01-28-2010   #30
way2fastalon
IS Broken :-/
if i was going to run it. id do a t3 flanged manifold top or bodom mount
but its for sure a T3/T04E turbonetics Compressor Housing - 60-1 Compressor Wheel - F1-62 Turbine Wheel - Standard Housing - .63 A/R fully clockable the whole thing comes apart easy 5 bolts to take off on exhaust side from the center section and 4 for the compressor side off the center section and another 6 on the compressor side around it
best part it was free ill post pictures
like i said earlier im my post going to max out the e16 first then try to run this or fix it and sell it
+more mods to list
Old 01-28-2010   #31
93tsiawd
Drives: 90 gst
if your looking to get rid of that 16g im in need of one for my project. lmk
99 Jaguar XJ8 (cruiser)
96 Civic Ex (sold)
90 Eclipse GS-T (sold)
90 Talon Tsi Awd (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
93tsiawd is offline   Reply With Quote
Old 01-28-2010   #32
way2fastalon
IS Broken :-/
http://www.rsaperformance.com/meramidsmt3t.html
+more mods to list
Old 01-28-2010   #33
mlomker
*Resting In Peace*
mlomker's Avatar
It's great that you guys can buy new parts for so cheap. My X mani was nearly 4x the price.
Old 01-28-2010   #34
Well you're buying good quality stuff. Megan racing stuff, I would not expect a manifold like that to last...maybe it will, I'll eat my words...their o2 housings for the evo8/9 have proven very reliable...but idk, plenty of those cheap manifolds crack pretty quick! I'm sure they'll have a manifold for the X for about $200 pretty soon too, but I doublt it'll stack up to your FR manifold
Old 01-28-2010   #35
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
The one car that the Ebay/Megan racing manifolds don't seem to work on is DSMs. They work great on supras, hondas, 240s, etc though!
'04 Honda Ricer: stock
Old 01-28-2010   #36
93tsiawd
Drives: 90 gst
if you want to get rid of that 16g pm me im in need of one. if its a real one
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-28-2010   #37
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
In case he didn't see your post 5 posts above?
7/25/09
Old 01-28-2010   #38
93tsiawd
Drives: 90 gst
i dont think he did lol..since he replied after my post but didnt give me an answer
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-28-2010   #39
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
Just PM him. He can't miss that
7/25/09
Old 01-29-2010   #40
way2fastalon
IS Broken :-/
Talking Re: 1991 talon 500 hp project
here are the pictures of the turbo i got
+more mods to list
