Old 01-29-2010   #21
Re: 4g63t modded estimated awhp?
850's will be just fine. 95tsi is maxing the shit out of his e316g (30 psi, 40lbs/min) on a 2.3 and has 880's. Maybe he can chime in on what his injector duty cycles look like.
Old 01-29-2010   #22
You can't ever have a very good SAFC tune, since all it does it trick the ECU by modifying the MAS signal. It can't change the ignition timing directly(it does indirectly, often not in the way you want), it can't scale the injectors correctly, it can't adjust the revlimiter, it can't get rid of fuel cut, etc. You can usually get a decent enough with 550s and an SAFC on pump gas or 750-850cc on E85 though. You might want to get some cams. A low compression stock 1G motor with a 1G head and a small 16G isn't going to make amazing power or anything.
Old 01-29-2010   #23
850cc aren't that small if he's sticking with the small 16g. You could easily get 300whp out of those injectors on e85.
Edit: I guess everyone else already said this while I was typing.
Old 01-29-2010   #24
93tsiawd
Drives: 90 gst
aight..dam alot of info lol thts y i love this site haha..but newayz dnt really have the $ for a dsmlink right now..what u guys i suggest i do with the mod list i have now?
99 Jaguar XJ8 (cruiser)
96 Civic Ex (sold)
90 Eclipse GS-T (sold)
90 Talon Tsi Awd (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
93tsiawd is offline   Reply With Quote
Old 01-29-2010   #25
Look to be setup pretty good for pump gas right now, but if you want to go with E85, I'd say 272's, Link, and 850cc+ injectors.
Old 01-29-2010   #26
DSMLink Lite is $345 or less. I do chip tunes on the dyno for less than the cost of getting an SAFC and dyno tuning it also. You will need to do something about your MAS though too. Either a 2G MAS or hack the shit out of your 1G MAS. You can max out a stock 1G MAS on the stock 14B turbo.
Old 01-29-2010   #27
93tsiawd
Drives: 90 gst
aight how about since i cant afford a dsmlink right now ill leave it on pump gas for now..so the most i could prly get without e85 is around 220ish?
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-29-2010   #28
mike55112
mike55112's Avatar
Drives: 04 evo
You could still use E-85, just have shane tune your car and burn you a new chip. Then save for Link.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 01-29-2010   #29
93tsiawd
Drives: 90 gst
i was plannin on havin joey at excessive autosports tune it
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-29-2010   #30
93tsiawd
Drives: 90 gst
im confused on what to do now lol cant make up my mind
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-29-2010   #31
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Originally Posted by Andrew7dg View Post
again, safc isn't meant for 850cc You will be disappointed IMO
an SAFC is meant just for those 550-650
get a 2g mas with those injectors and tune out with the safc
you are pretty well setup for pump gas!
Save your money for DSMlink and upgrade later when something blows
I loved my S16g when it was working and when I had a similar setup.
Get a 2g MAS (pm me I have one with pig tail)
550 or 650cc
Your SAFC will be fine on pump gas and the combo of a 2g mas with 550cc injectors
(2g mas sees 10% LESS air then a 1g mas. Put in 550 injectors will yeild you 20% MORE fuel and then use the SAFC to correct the 10% difference
correcting using the safc for 10% isn't that bad. Probably run like stock. People just use the 550+2g mas just by them selves without safc and some are fine.
650 will have a 30% increase of fuel 2g mas sees 10% less air meaning you have to tune out 20% with the safc, which can be done... but doesn't run quite right.
There is nothing wrong with pump gas. I would wait for a bigger turbo before hitting the E85 unless you want to fully max out that S16g
hope I didn't confuse you but just showing you what you have for options
PS you may be thinking you want 300 or more horsepower, however take it down to the track
you will forsure hit 12s in which is one quick car then for minimal mods...
In my experience with E85, you can't get the full benefit of it unless you have a standalone. You have to adjust the timing tables (which SAFC doesn't do) and other things before you really see the benefit of 100~ oct. Plus it changes in the winter (which I haven't seen too much of a change but I haven't driven my car that much) so you need something to tune before switching.
Some people will disagree with me about needing standalone but this is just my opinion.
Old 01-29-2010   #32
93tsiawd
Drives: 90 gst
550 or 650cc
so how much whp should i be at with the suggestions u showed me? 1/4 mile run?
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-29-2010   #33
CarPsyco84
CarPsyco84's Avatar
1/4 mile times are largely based on the best mod of all, the driver mod. I've ran a 12.24 on a big 16g with 550cc inj. SAFC I ACT 2600 clutch and big exhaust. But some people are scared to launch their cars hard, or short shift cause they think its gonna blow.
-When in doubt, Moar RPM.
Old 01-29-2010   #34
Andrew7dg
Andrew7dg's Avatar
I think a better question is what goal of HP or 1/4 mi do you want for your car?
Once that is answered we can tell you what you need for your car.
Want to be in the 12, 11, 10s We have all sorts of answers for that.
Or do you want just a fast street car. We have answers for that too.
Old 01-29-2010   #35
93tsiawd
Drives: 90 gst
lol pretty much a fast street car..with that setup i was talkn about i was hopin for mid 13's..
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-30-2010   #36
Constant_Project21
Constant_Project21's Avatar
Drives: E36
I really liked my small 16g set up (safc, evo 560cc injectors, hks 264's, fmic, exhaust, etc). Really quick spool, buy had jack sh*t for top end. It was definately fun, I beat some big 16g cars (was 2g gst, farting around on the freeway), with a driveway tune lol. I never really got it dialed in. If you just want a fun street car, you can have that with the set up listed. I used only 93 ultimate, ran like 24psi, with it awd 1g.
Old 01-30-2010   #37
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
I'm sure 272s, e316g, dsmlink and you've got a pretty sweet ride. The Galant is more than fun with just the e316g...can't imagine it with 272s, e-85, 1000cc injectors, dsmlink. I'm sure with mods you get, the car should be in the high 12s...but it is ALL driver mod.
ლ(ಠ益ಠლ)
Old 01-30-2010   #38
93tsiawd
Drives: 90 gst
k..so do i have a pretty decent setup?
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
Old 01-30-2010   #39
CarPsyco84
CarPsyco84's Avatar
Yeah, I know a person on here that ran low 12's in a AWD all day long on a small 16g, E-85 would unlock more power than 92 oct, but its up to you whether to buy the 255lph pump and ~880cc sized injectors or not. I guarantee that once you have that setup running right you will have fun with it, I miss the boost snap in 1st from the AWD's. Hell Alpha D's car with like 8psi feels fast compared to my fwd.
Old 01-30-2010   #40
93tsiawd
Drives: 90 gst
yea i thnk im going with 880cc injectors with the walbro fuel pump n e85 n the setup i was talkn about
96 Civic Ex (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
