Old 02-06-2010   #21
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: Strange mis-fire problem
So how did you come to the cunclusion you need a maf? You just said in your first post that when you unplug it, the car dies.
Just because you tightened couplers doesn't mean the intake pipes are sealed. Just go outside, make a tester and get to it.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 02-06-2010   #22
CarPsyco84
CarPsyco84's Avatar
Is the Ecu stock? Alpha's car did something similar with a 1g maf in it, when he put the 3g one it came with back in it ran perfect... Whatever maf you use, the ecu has to be setup to work right with it. Just because it dies when you unplug it doesn't mean the maf is good, they can fail at higher airflows only.
-When in doubt, Moar RPM.
Old 02-06-2010   #23
Eurotrash
Drives: 92 Laser RS
The car has an Eprom ECU, ive been hearing that the stock MAF doesnt work with this??
Eurotrash is offline   Reply With Quote
Old 02-06-2010   #24
CarPsyco84
CarPsyco84's Avatar
Depends on if its a stock chip or a aftermarket chip that someone put in there I would assume. Certain 1g's came with eprom's from the factory so they would have to work with a stock 1g maf.
Old 02-06-2010   #25
Sounds like it needs a boost leak test and a tune. Bring it to Shane @ DB, he can straighten you out.
Old 02-07-2010   #26
Eurotrash
Drives: 92 Laser RS
un-plugged the MAF and the car runs mint.. lol?
Old 02-07-2010   #27
CarPsyco84
CarPsyco84's Avatar
try a different maf? they can fail you know...
