Old 03-18-2010   #21
LingLing
AznKraut
LingLing's Avatar
Re: LingLing's Project Thread
Originally Posted by Kevin 1G Drummer View Post
Sucks about the tranny. What happened?
Not sure yet, I went to Taco Bell, pulled away from the window and it sounded like my gearset was dragging on the ground. The end cover is cracked wide open and she bled to death. It's right where 5th gear is and that was the gear that was popping out and giving me trouble so it kinda makes sense. Oh well!
of course pump numbers were 210/192ish
Wow, that's a huge difference. I can't wait to see what I'll end up with!
Originally Posted by blackrosenova400 View Post
Id say your injectors are good for around 320hp with e85. A rough estimate in my head says you will be around 80% duty cycle with 950's at 290hp. Max they could pump is around 350-360 at 100% duty cycle. This is at base fuel presure of 37.5. Id say you have plenty of room with your injectors.
320 is right around what I figured I'd be able to make with the current fuel setup. I'm hoping I can get on the dyno by June or July. Since it sounds my fuel system will be pretty much at it's peak, this winter I'll look in to upgrading my injectors and pump so come spring time I can get back on the rollers and really stretch the e316g's legs out.
Old 03-18-2010   #22
Wait you have 950s?
Then WTF are u worrying about thats what I have and I am not even close, you have nothing to worry about.
Black is right, i say let er buck you will have more fun trying to get more boost than worrying about fuel with a 16G and 950s.
Old 03-18-2010   #23
Your estimate on duty cycle is a little high. When I had the car tuned at DB with the 3076R I was making 305whp, and IDCs were only 65-70% on 92. Those injectors should be good to 350-375 on E-85.
Old 03-18-2010   #24
LingLing
AznKraut
LingLing's Avatar
Wait you have 950s?
Either way, I'm in for a lot of
Old 03-18-2010   #25
And that's weird about the tranny popping out of 5th, then blowing it out of the cover. I can't say I've heard of that happening before and it never popped out of 5th for me.
Old 03-18-2010   #26
LingLing
AznKraut
LingLing's Avatar
It was weird, it didn't do it when I test drove it, just bad timing! In no way do I blame you Kevin. You sold me a damn solid car. Things happen! At least it happened when I have some extra dough laying around! She'll be back up in a few weeks I think. Stronger than ever!
Old 03-18-2010   #27
Yeah, Shitty timing on it happening for you, but I'm glad you're getting it sorted out.
Old 03-18-2010   #28
if you want to fix the tranny I still have alot of parts from the parts tranny on the shelf. also have the case
Old 03-19-2010   #29
The nut that holds 5th gear on can work its way loose, and then worse case scenario fall off or something. I guess a symptom is popping out of fifth.
What route are you going with the tranny?
Old 03-19-2010   #30
blackrosenova400
blackrosenova400's Avatar
Hes picking up another this weekend and Im going to inspect it and swap thru shafts for the t-case if needed.
20g Mafia
Old 03-19-2010   #31
I guarantee that's what happened Ling Ling. Here is a pic of that same nut from my 1st tranny. Except in mine, the nut actually sheared right off with a piece of the shaft still in it.
Old 03-19-2010   #32
Also, if you have 950cc injectors and a Walbro 255HP, you have plenty of injector and fuel pump. Here is a video of a buddy of mine's setup (95tsi on here) And he has quite a few more mods than you on an E316G and E-85. He is on 880cc injectors and made 347HP and 361TQ.
http://www.youtube.com/watch?v=nkiSpSxJJ0Y&hd=1
Old 03-19-2010   #33
LingLing
AznKraut
LingLing's Avatar
Just a stocker, I was hoping this transmission would last me through this year, so then when I garage it for the winter I could upgrade then, but since I'm getting the replacement checked out by Chad so I'll be okay for a while I think...I hope
I'm damn near positive you're right. The timing with 5th gear popping out and the case cracking it makes perfect sense. I suppose it could be a lot worse.
That's a nice car! My expectations are being raised the more I read about e85 with the e316g.
When the transmission is out I'll be be doing the fuel pump rewire and addressing some of the small stuff. There's still a hefty exhaust leak from between the manifold and turbo, so a gasket is definitely in store. Also, the VC gasket is starting to seep a little, and it seems pretty wet by the oil pan too. Overall it'll be a good time to get a lot things done.
Old 03-23-2010   #34
LingLing
AznKraut
LingLing's Avatar
Figured while I have some time I'd actually try to get something done on the car. So I relocated my wideband to a more visible spot. I didn't like how I had to physically look down to see it when I'm driving.
Old 03-23-2010   #35
^That spot is way worse IMO, I like looking at the gauge cluster in one glance see everything I need, but whatever u like.
I can't believe you are underestimating E85.
Old 03-23-2010   #36
LingLing
AznKraut
LingLing's Avatar
Before it was below the stereo and it was a bitch to just glance at it. I would like it mounted on my steering column eventually, but this will tide me over for now.
I no longer underestimate the power of e85. I've been doing some serious reading and now I know I was short changing the potential of it. No further mods until I max out the e316g! Thanks to everyone who opened my naive eyes to power of e85!
Old 03-23-2010   #37
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
I told you so Ling Ling! 16G FTW! Untill you get use to it again
Old 03-23-2010   #38
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
yeah, e85 is no joke...it will seriously make you laugh because of the gains . My cousin with a 2000 WRX RS w/ the ver.7 sti swap went from, IIRC, 280 awhp to around 340awhp from just switching to e316g+e85+tune. that car seriously goes. did i mention he did that with the e316g?!! i want a ride when you go ethanol!
ლ(ಠ益ಠლ)
Old 03-23-2010   #39
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
ITS GOOD FOR THE ENVIRONMENT AS WELL! Dont listen to those ppl that whine about fuel economy Youll Be Kickn it Green N Sidewayz Yoo Mad Powwwaa!
Old 03-23-2010   #40
If you think that, you are either seriously retarded, or haven't read anything about the process in which it takes to make E-85
