Old 04-07-2010   #21
Re: That'll do, pig. That'll do.
Couldn't make the 420, waste gate spring was not strong enough, but here's the business:
First one is the 61mm at 21psi in red with the 62mm at 22 in blue
Old 04-07-2010   #22
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
What does that come out to in shootout mode? Did the other guy dyno on a dyno dynamics or a dynojet? If dynojet you have him beat.
-1990 Mitsubishi Cyborg 4WD-
Old 04-07-2010   #23
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Nice numbers man, I want a ride.
Old 04-08-2010   #24
He was on a Mustang dyno, I've already beat his torque number, he has an unusually low number of 405 or something like that, I think it's really peaky too, but I'm not sure. Anyway, I'll give rides. It's fun when it spins 'em through second gear, but it depends on the pavement. I bet with little fuel and no passenger it'll spin in 3rd. I was on some cement today getting on 394 in 4th and punched it. It spun something, I'm thinking the tires and not the clutch only because it didn't start to smell and the car was actually kind of accelerating still.
Old 04-08-2010   #25
Constant_Project21
Constant_Project21's Avatar
Drives: E36
That's awesome!! Must be a blast to drive. I've only gotten to ride in a pretty stock conquest (Julian's), would like to take a ride in a modded one.
Old 04-08-2010   #26
Pretty good numbers! How was the wastegate spring limiting hp? Boost looks flat all the way to red line.
Old 04-08-2010   #27
Because he was trying to run more boost than the spring would allow.
Old 04-08-2010   #28
Wow good numbers! I like the torque!
Old 04-08-2010   #29
Yeah, Shane mentioned when I asked about the WG that whenever you go over double the spring pressure you might have problems controlling the boost. I have a seven pound spring in mine.
22 it does fine, but above that it seemed to just push the valve open on it's own. Too much pressure in the manifold. I played with the gain on the boost controller and it stopped doing that thing that sounded kind of like surge but wasn't. Again, the wastegate was popping open as boost was climbing and making boost come on late. Now it's like lighting off a JATO rocket.
Old 04-08-2010   #30
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
nice numbers! Looks like a torque spike at 4700 and drops off fast... would the waste gate fix that problem? Or is this a SOHC head flowing problem?
So when you mention you want to break the 420 hp, is that the highest HP 4g54?
Old 04-08-2010   #31
Damn that little spring! Nice conservative power man, should be hella fun!
Only thing that is a little shocking to me is how much higher the boost threshold of the 6262 is compared to the 61mm. Billet wheel you'd think it would spool faster, or at least make better/equal torque when off boost.
Do you think you'll throw a stronger spring in there and retune, or just leave it as-is for a while? Seems like an easy fix for another 30+whp, would get ya over 400 pretty easy.
Old 04-08-2010   #32
way to go
Old 04-08-2010   #33
RS98GSX
RS98GSX's Avatar
Drives: White on White 98 GSX
Nice car, Nice numbers where did you tune at man?
RS98GSX is offline   Reply With Quote
Old 04-08-2010   #34
DB Performance, you know as it says on the dyno sheets. That is where the majority of us go.
Old 04-08-2010   #35
D_Venable
SQ addict
Drives: 85 and 88 Conquest (plus a 2011 Silverado)
Send a message via AIM to D_Venable
The highest I've seen without a solid billet head is 721 (back halfed car)
I think the highest on pump gas is in the high 400's
D_Venable is offline   Reply With Quote
Old 04-08-2010   #36
Boo the shitty little spring.
Congrats looks even more fun than last time. Go get some damn real WG springs (24psi) and go back.
Old 04-08-2010   #37
Old 04-08-2010   #38
My heater core leaks, and I just broke the transmission (just bearings, still drivable), but either way I need to take it out and put a new one in there. And the heater requires removal of the entire dashboard. It's an old car with problems. But it's good and quick. I might leave it right now and fix the problems, then later I'll come back for more. I'm going to work on a nice header, stiffer spring and other things.
Old 04-11-2010   #39
Looking good Andrew. If you went with a stiffer spring closer to your target boost you might gain back some of that spool-up as the wastegate would be held shut longer/harder.
Man this car has come a long way from where it started, excellent work.
Old 04-11-2010   #40
Thanks Josh! It's been fun, expensive, and it still feels slow! Haha. I still like it though, and with a little reworking, should have a torque peak at higher RPM, and eventually, if I'm lucky I'd like to run over 25psi (30 would be my goal). 425whp at 25-26psi would be great. Some guys in Florida made 510whp with like 40psi, haha. I don't know how but they pulled it off, but usually it's right around 30psi for the 500 mark.
