Old 05-01-2010   #21
WRX
Drives: 2007 Subaru WRX Limited
Re: All we wanted was some BBQ...
OMG. Did you at least cut the dude?
I tried. Chris made me get back in the car.
WRX is offline   Reply With Quote
Old 05-01-2010   #22
My prison shank got lost in the shuffle. I was going to try and get him right under the ribs too.
Old 05-01-2010   #23
Shitty month for all the guys at least it is may now.
4 evo's in on month is to much.
Old 05-01-2010   #24
The Mitsubishi gods are smiting us.
Make sure that the car is perfectly straight when it's done, things like to bend in half when they're hit like that.
Old 05-01-2010   #25
mlomker
*Resting In Peace*
mlomker's Avatar
Isn't it 5? I guess it depends on whether you're going by calendar months or not.
spaz
murlo
you
Old 05-01-2010   #26
Definitely. The body shop already said they'll get it up on an alignment rack to make sure everything is straight. I just got the car aligned last weekend too so with that spec sheet it will be very easy to compare. I seriously woke up this morning just sick to my stomach not believing that this actually happened last night (maybe partly because I ate 15 boneless wings too).
Old 05-01-2010   #27
What I mean is that just because the wheels are all pointing in the same direction, that doesn't mean the chassis is. If I were you I'd get under the car with a piece of string and make sure everything is straight, front to back. Was the rocker panel underneath the doors damaged? What about the B pillar being pushed in?
Old 05-01-2010   #28
The side skirt looked 100% perfect this morning when we went back to inspect the car with the body man. We'll see about the B-pillar once the doors come off; the hinges were tweaked but that may be all. This isn't a State Farm "approved" body shop so I don't expect there to be any behind the scene shenanigans going on, but I will be sure to really look the car over after the repairs to ensure it's just as straight as before.
Old 05-01-2010   #29
LingLing
AznKraut
LingLing's Avatar
WTFBBQ!? As I was on my way home from Swifty's, Tom called me and told me what happened. I'm just glad you guys are okay. This thread makes me sad.
Old 05-01-2010   #30
spaz
murlo
you
What happened to Mark and Murlo's car's?
Old 05-01-2010   #31
My engine blew on the way home from getting tuned. That is why I did not drive it on the cruise
Old 05-01-2010   #32
^^ Oh, I knew about that, I guess I was thinking more of cosmetic damage.
Old 05-01-2010   #33
Murlo threw a rod out the block.
Old 05-02-2010   #34
Wow, that's super shitty! I'm glad everyone is ok.
The B pillar looks like it might be pushed in a little, as well as the lower part of the A pillar, but those are easy enough to fix. I wouldn't be at all surprised if they throw it on the frame rack to pull the pillars out, throw a couple new doors and a fender on it, and send you on your way.
Old 05-02-2010   #35
cmspaz
Walls need hugs too
cmspaz's Avatar
Yeah, I was over at Scheides' earlier, and we decided that it's Trevor's turn next, seeing as the destruction has moved on from the black ones to the white ones...
It appears to be a shitty time to own an Evo.
Originally Posted by Trogdor
Old 05-02-2010   #36
Shut up Matt D., Don't u dare include DSMs in this mess.
Its not the EVo's fault, its the stupid burnout fuck that had earphones in his ears and wasn't looking at oncoming traffic.
God that evo was so nice.
Last edited by turbotalon1g; 05-02-2010 at 11:58 AM.. Reason: Fuck Texas burnout pieces of shit
Old 05-02-2010   #37
Crazy! Glad no one was hurt.
Old 05-02-2010   #38
polishmafia
Smells like cat poop
polishmafia's Avatar
JFC! Oh man, glad you guys are ok. This hasn't been a good few weeks for Style.
Old 05-02-2010   #39
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
good times to pick up evo Xs i guess...
Old 05-02-2010   #40
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
Sorry to see.
