Old 06-28-2010   #21
C89ZX7R
C89ZX7R's Avatar
Drives: 87 and 89 Chrysler Conquest
Re: Rebuilding the 87 Conquest TSI
Hood, Fenders, Engine Bay Wiring, Maf Hard Pipe, Brake Master Cylinder, Steering Column, 89 Steering Wheel, 88 Auto Radiator Fan, Battery Tray, Relay Box, Igniter and a few other things were installed.
Getting there. Need to do some minor wiring, add the front bumper and airdam.
Motor Is Tight, Sounds Unbelievably Badass, Intimidates Slow Hondas Instantly
C89ZX7R is offline   Reply With Quote
Old 06-30-2010   #22
C89ZX7R
C89ZX7R's Avatar
Started the car and turned it around......Still needs some tlc.....
Installed the gas tank, changed the fill tube to tank rubber hose and added a anti-roll over vent. Anti-roll over vent has to be installed to vent the tank when you remove the charcol canister. Gas tank caps only allow to vent "IN" not "Out", the valve will go both ways but will close when liquid or alot of pressure hits it. The top left hose is the vent line, it wraps around and that little white ring near the zip tie is a fuel filter. Then it goes to up and sits above the gas tank lid, see next picture.
Because I didn't want excessive fumes building up in the fender I added another hose which takes all the fumes and liquid if any to the ground behind the rear tire.
Old 07-06-2010   #23
C89ZX7R
C89ZX7R's Avatar
Need to add 2 bolts per side on the airdam and wire the horns.
Old 07-06-2010   #24
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Wow, that thing has came a long way. Looks good!!
Old 07-07-2010   #25
#801vr4
#801vr4's Avatar
Drives: 92' galant vr-4
lookin sick man!!
#801vr4 is offline   Reply With Quote
Old 09-10-2010   #26
C89ZX7R
C89ZX7R's Avatar
Since it has been on the road the following has been done, with-in a month lol...
Gr-2 Rear Shocks
Suspension Tech Lowering Springs
Painted The Valve Cover Yellow
Accel Coil
KDM Turbo Discharge Pipe
Rotella T6
Wix Filter
Red Top Optima Battery
105/110 Amp GM Alternator
Alternator Bracket
Two Alternator Charging Wires
Fog Light Mod
Update from yesterday!
Hit 5,000 rpms the other day and noticed a pop in the car. There was a ton of vibration but no knocking noise. Thought a jet valve got stuck open. Pulled the valve cover and check everything. All up top seemed good. Checked the flywheel to see if it came loose, but that was also tight. Today I pulled the oil pan out and noticed a balance shaft bearing has walked out of where it's suppose to be. Since the shaft was rubbing the bearing it flared out the bearing. See the picture. Its not suppose to be out that far, its suppose to be flush. So now I will be ordering everything to get rid the the shafts altogether. Each way roughly 15lbs, so 30lbs off the rotating mass is like having a 1 ounce flywheel lol... Plus the oil pressure will go up once there gone.
6 piece Balance Shaft Elimination, Jet Valve Elimination, Valve Cover Gasket, Oil Pump Gasket, Timing Cover Gasket Kit, Oil Pump O-Ring and Oil Pan Gasket = 110 bux shipped.
Old 09-10-2010   #27
Yep, Balance shafts make the motor nice and smooth, but things like that can happen.
Old 09-10-2010   #28
C89ZX7R
C89ZX7R's Avatar
Pulled it all apart today. Just need to clean up some parts and wait for the parts from "Dad" vendor on SQC to come in the mail. I'm removing the yellow paint from the valve cover.
Paint will be
Intercooler pipes "Wrinkle Red"
Valve and timing cover "Wrinkle Black"
Other parts and brackets normal gloss black.
Old 10-07-2010   #29
C89ZX7R
C89ZX7R's Avatar
Its been on the road for 2 weeks. Wrinkle black the valve cover and timing cover.
I have Eibach Pro springs coming and rear d2 fixed strut tops also coming in the same box.
Old 04-26-2011   #30
C89ZX7R
C89ZX7R's Avatar
Added some parts to it, including these rare hard to find death mounts. Stedebani only made a few on the first run and then stopped making them due to everyone complaining they were too stiff. They are rated at 95A durometer.
Decided to not sell the Grant Wheel, so I installed it. The above mounts were making the radio controls vibrate "noise" on the factory wheel.
Eibachs in the rear and Suspension Tech lowering springs on the front. Also just painted it flat black yesterday lol.
240Z bolt on master cylinder reservoirs got rid of the single corner mounted one.
Will update the first post shortly with a mod list!
Old 04-26-2011   #31
hareboy1979
pretty sweet ride
hareboy1979 is offline   Reply With Quote
Old 04-28-2011   #32
C89ZX7R
C89ZX7R's Avatar
Updated the bottom of the first post with current mods.
Old 04-29-2011   #33
Mnementh
Mnementh's Avatar
Drives: '87 Chrysler Conquest
FYI, the '88-89 Starquests have a different steering wheel with radio controls on it. (read no fake chrome/peeling or noise)
Mnementh is offline   Reply With Quote
Old 04-29-2011   #34
wants to be sideways...
123abc's Avatar
Drives: Loud cars
I like the way it looks with the flat black paint. Love those motor mounts too...lol
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 04-29-2011   #35
That flat black looks really cool actually!
Old 04-29-2011   #36
Is that a Stealth fighter or a Lamorghini Revention?
Old 05-05-2011   #37
C89ZX7R
C89ZX7R's Avatar
Painted the rims today!!!
Old 05-05-2011   #38
C89ZX7R
C89ZX7R's Avatar
I know, I have owned 10. The 88-89 version was the one making noise.
Old 05-19-2011   #39
C89ZX7R
C89ZX7R's Avatar
