Go Back   MitsuStyle > The Homefront! > The Parking Lot - On & Off Topic > Video Forum
Old 08-27-2010   #21
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Re: auto dsm moving out!
And a upgraded valve body, tranny cooler and manual shift controller also I'm sure.
Aaron might now, since he's got an auto now
Yeah. I was only told about the converter and shiftbox for my Talon by a guy who said they can run 10's pretty easily.. But for the car in the video I'm sure it would require those as well.
Old 08-28-2010   #22
blackrosenova400
blackrosenova400's Avatar
They have upgrades clutches in them and run 100% clutch pressure, upgraded cooler of course, tuned torque converter.
I will be going auto myself aswell.
20g Mafia
Old 08-28-2010   #23
CarPsyco84
CarPsyco84's Avatar
Yeah, the torque converter is key I'm sure.
-When in doubt, Moar RPM.
Old 08-28-2010   #24
santa
Boost Spike
santa's Avatar
Tq converter, full line pressure, end clutch's and a big ass cooler. My auto trans should be here later next week. I'll be making a build up thread on it and share my results.
Old 08-28-2010   #25
I didn't read back but until you pass 400whp thru the auto there really isn't much to worry about, I'd say brad, santa and maybe blackrose are the only people that need to worry about the auto.
I'm staying slow so I'm rocking a stock auto
Old 08-28-2010   #26
Autos are good for the 1/8 mile, but if you run the 1/4 and make some real power you'll run out of engine before you run out of track.
Old 08-28-2010   #27
blackrosenova400
I dont get this statement, please elaborate.
20g Mafia
Old 08-29-2010   #28
If you watch the first video you'll see he's well into third gear by the end of the 1/8 mile. Check out the night time in car camera and you'll see he's about to bury the tach again in 3rd gear before he let's out. Only shift left would be OD. Add another 1/8th mile to it and you run out of gears. So unless you are building a really high revving 2.0L you'll be hitting your rev limit before you reach the traps. I've read where people look for taller tires, etc., to help keep the rpm down.
Old 08-29-2010   #30
santa
Boost Spike
santa's Avatar
Those cars are all doing 150-160 in the 1/4 running high 8's No problem shifting into od(4th). Thats why the end clutch is a necessary upgrade. I rev my car to 8500rpm, and if need be I'll rev to 9000rpm on my 2.3. You'll want a bigger displacement motor for the auto just for the shear reason you'll need the lower end tq to get up onto the converter to launch. Most of these auto guys are using nitrous to get on the converter and then shut the nitrous off before they run down the track. I'm hoping to not need the nitrous!!
Old 08-29-2010   #31
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
neutral drop ftw!!!
Originally Posted by 311evo
Old 08-29-2010   #32
^You should do that from 7k about 15 times in a row and report back.
santa, just spray the whole damn time.
Old 08-29-2010   #33
CarPsyco84
CarPsyco84's Avatar
15 times eh? I give it 2 times before something exciting happens, It'd be lame anyway cause you still wouldn't have any boost and it would bog big time.
Old 08-29-2010   #34
If you can't build boost with an auto at the line you need a looser converter. Or at least anti-lag.
Old 08-29-2010   #35
santa
Boost Spike
santa's Avatar
You can't use anti lag with a auto trans really. The trans is the load. You can only go so loose with the converter before you loose all your top end power. If I can get the converter to stall out at 4-4500rpm I'd be very happy with that. I don't think I'd need any nitrous then as my boost comes on hard.
Old 08-29-2010   #36
I think you can run anti-lag with an auto, all it does is reduce the timing and richen up the mixture while engaged. But I never tried it, so I can't say for sure.
Old 08-29-2010   #37
santa
Boost Spike
santa's Avatar
The whole reason why you need anti lag with a stick car is because there is no load being produced by the engine until you let the clutch out. The converter is what cause's load on an auto car. You will not need anti lag to launch.
Old 08-29-2010   #38
Anti-lag will actually hurt you trying to get up on the converter.
Old 08-29-2010   #39
CarPsyco84
CarPsyco84's Avatar
Yeah, cause when your timing is retarded that far you loose all your power, you might be able to comprimise but adjusting the timing slightly around where it stalls, less timing spools faster, but makes less power...
Old 08-29-2010   #40
Orrr instead of worrying about losing top end from a loose converter, you can get one of the late model dsm autos that have lock-up converters.
