Old 09-20-2010   #21
travail
travail's Avatar
Drives: EV0 8
Re: Miata+4g63+T56=awesomeness!
Originally Posted by cudvig View Post
I am currently researching this project.
I am currently building a narrow block 4g63. I plan on using a T56 transmisson but could also opt for a T5. I have researched the FC transmission from a turbo rx-7. It would be a lot easier if I could find a wideblock 4g63 or 4g64. I have not started looking into rear ends but I could imagine I could have a huge list of possibilities. I want the car to hook up and hopefully with the right combination of tranny/rear end I could end up with some high top speeds also. haha! I plan on spinning the motor to well into 9000 rpm and making 400-500 HP with a 35R or maybe 50 trim?
I have a couple of questions:
What do current owners of a T56/FC/T5 know about them? Power levels? TQ holding? possible to spin to 9000RPM?
should I use solid motor mounts?
Will evo intake manifolds bolt onto a 1g/2g 4g63? I have some rerouting to do with the manifolds but oh well they will be getting replaced anyway.
Any other comments/suggestions welcome!!
Discuss,
Colin
I had a T-56 in my lt1 turbo 2 with 4.10 gear in 6th gear at 55mph you are about 1700 RPM. I have a buddy the has a 450RWHP NA ls1 FC with a 150 shot the rear end has work good for him.
travail is offline   Reply With Quote
Old 09-21-2010   #22
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
I also opt for the TII Independent rear suspension.
Less fabrication and less expensive IMO
