Old 05-07-2004   #21
SlowWhite
Been there, done that.
SlowWhite's Avatar
I ran a Greddy Large 24Row FMIC with a HRC S20G turbo
Ran it at 20psi on 92 oct daily for 3 years during the 4th summer I played with 22-25psi on 92 oct daily. using the Standard couplers with "0" problems of Pipes blowing off, when I actually pressed the pipes together correctly. If I did a slack job they'd blow off.
My car put down 321whp Maxed out on pump. I have over 150 pulls on the dyno with this set up through out those 4 years
My setup up:
HRC S20G complete kit
HRC I/C piping
Greddy 24Row FMIC
Blitz BOV
HKS 264/272 cams
BPR7ES Spark Plugs
Magnacore 8.5mm Wires
Walboro 255 Fuel Pump
Used 550's, 660's, and 850's Inj (changed up twice during the 4th summer)
SAFC
ARP's
Clutch Masters Stg 3 Clutch
Ported 2G Exhaust manifold
MBC
EGT on the #1 runner
When I was at Tuned for Max HP on pump gas. My EGT's were at 1300 during Cruise, and at 1575 at WOT.
When I first started Tuning - I was told you have to tune so that your EGT's Gradually go up as you go through the gears.
Wel I started at 1000 and by the end of a WOT run I was at 1375. - I took that tune to the dyno and put down a wooping 255whp 20psi on 92 oct.
As for the Greddy FMIC - I changed it up to the SKYLINE GTR FMIC because it flows better. and use's Shorter/Larger Piping.
And since I was planning on running a Much larger turbo then the 20G I needed a better FMIC.
But I will say this - Jeremy suprised me when he put down 470whp with an FP Green and Greddy 24 Row FMIC at elite on C-16. But I think he had upgraded to larger I/C piping?
Most most people will say a greddy 24 Row is good up to a 20G Sized turbo anything larger and you'll need to upgrade.
I'll say this. - I beat the living hell out my My GS-T every single day I drove it. (why modify if you don't plan to use it)
Personally I think the GTR is an all around Better FMIC. Contstruction, Design, Flow, etc. It didn't change HP much for a turbo the size of a 20G but for the larger turbo I'm going to be running I have no doubt it will be a huge difference.
-brian
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
Old 05-07-2004   #22
I was talking about the large one Enes.
CRAIG
Old 05-07-2004   #23
JasonR
Guest
Tournaments Won: 6
Posts: n/a
Quote (Jet @ may 7 2004, 9:26 am)
Your EGT's should be higher than 1300 deg F. You say you are tuned right, how do you know? Your AFR's may be right, but then you need more timing if your EGT's are that low. Heat = expansion = power.
mmm, certainly got me thinking. If I add more timing then I have with dsm link at high rpm's I will get adverse effects. We added as much as we could, but she started pulling (ecu). Under load a/f ratio good, no knock, timing avg. 18-20 and o2 voltage .94 at 20 psi. Maybe if I drove for more then a minute under full boost I would see higher egt, but I have never done that, never auto crossed. Egt gauge goes from 0-16. If I get to 13, where are you at 0-16? Again, I did mention there are probably better fmic's out there. I feel greddy is one of the best for 2g.
Old 05-07-2004   #24
SlowWhite
SlowWhite's Avatar
Mine goes to 16 also.
Like I said my EGT's are constantly at 1300-1350 during cruise, and go up under WOT.
At the top of MY RPMS (8000, I also use DSMLINK V2 now) - they sit at about 1550 now.
For me on pump gas More timing = more knock, so we left my timing settings at Zero or during some runs we pulled timing by 1 in the upper RPMS.
I was seeing 15-18 degree's of timing at WOT at the end of a run.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 05-07-2004   #25
Bah, that is just like Chris C. last year. You have NO idea what your AFR's really are. Get a wideband or go to the dyno. Until you do you are untuned or 1/2 assed tuned. The DSMlink is guessing what your AFR is, just like the stock MAF tried to do. It obviously changes from car to car and there is no real feedback without a WB02.
Old 05-07-2004   #26
JasonR
Guest
Tournaments Won: 6
Posts: n/a
Quote (JET may 7 2004, 1:18 pm)
I explained before. Tuned car on dyno with wideband, how else can you know what a/f ratio is. Dsm link shows around 9.5 a/f under load because using stock o2. I have wideband installed in car to give me reference while driving, bunged on o2 housing along with stock o2, bunged on o2 housing. I have never tuned on street, probably take out 2-5 pedestrians or something, hell I would not have a engine anymore, how can you drive half ass tuned. Who the hell is Chris C. Anyone who knows me knows I am always thinking about the car and never satisfied with it. I am usually a nervous reck tuning on dyno. Always have help. Don't enjoy it until 3-4 pulls where you are safe. With the new cylinderhead this spring I was lien first two pulls. Some of the other reasons I have low egt is because aftermarket oil cooler, fuel cooler, radiator. I have spent way too much money on my car. Again a good fmic will have a cause and effect and bring down temp. of engine, dah. Greddy is a good one.
Old 05-07-2004   #27
Enes
Enes's Avatar
oh a fuel cooler too?
those really help on the dyno!!!!!
-E
Old 05-07-2004   #28
JasonR
Guest
Tournaments Won: 6
Posts: n/a
Quote (Enes May 7 2004, 3:10 pm)
[QUOTE]oh a fuel cooler too?
Are you implying a fuel cooler does not help? Brings down temp., but not enough to matter. Just paid for the lines and installed. Friend had core laying around. Oil cooler really makes big difference when driving. Nothing really helps a great deal on dyno because your not moving, dah. No air unless you have fans in front and good ventilation in dyno room. Why I dynoed at Hitech Motorsports up in Ramsey. New facility and expensive ventilation and 2 fans. One for fmic and oil cooler. Fans are there, why not use them. Elite probably has fans too. The oil cooler is from B&M along with sandwich and lines. Eay to install.
Old 05-07-2004   #29
Why did you reference a .94 O2 voltage if you have a wideband in the car?? That doesn't make any sense why you would even pay attention to a narrow band O2 sensor and not state what your WB02 was reading. Also, DSMlink should be approximating the AFR's from the fuel going in and the air going in. It shouldn't have anything to do with the stock O2 sensor. There should be a seperate logging input for that.
Also, a WB02 bunged that close has proven to be inaccurate in other applications. They should be 12" - 16" from the turbo.
Old 05-07-2004   #30
Stay on topic or all of this will be edited down to post that relate to the Greddy Intercoolers and piping.
Anybody can start a new thread in Advanced Tech if they would like to discuss WB O2's and such further.
Old 05-10-2004   #31
illz
Originally posted by JasonR@May 7 2004, 12:15 AM
First, I have greddy fmic, it has properly beaded pipes, ALL do, without t-bolt clamps my old hose clamps would not hold up on dyno after 18psi. T-bolt have better clamping force. Second I use pyrometer egt f * 100 gauge from autometer, sensor taped on manifold runner off of #1 cylinder. Gauge goes from 0-16. Under heavy load never seen it go past 13. Made 380whp on dyno chasis with my set-up and a/f ratio wot from 4.5 rpm-8.0 is avg. 12.0, almost straight linear line. Car is tuned correctly and runs great on c16. Again I think Greddy fmic is very good, probably even better ones now offered in the aftermarket.
yeah, no.
are your wrists more than an inch in diameter? tighten them more.
1300F peak in runner #1? that has nothing to do with your IC and everything to do with your car not running as well as it should, or it's time to replace your dying, innaccurate EGT probe. If you're using an autometer EGT gauge and have your probe in the manifold, that's a problem right there. How are you going to see spikes over 900C when the gauge tops out at 870C? This is why people use greddy egt gauges when they have the probe in the manifold (and it's pretty useless unless it's in the manifold).
Old 05-10-2004   #32
illz
a) O2 housing is not a good location for a WB O2. Should be farther from the turbo.
b ) thinking != knowing
c) oil cooler, radiator, and whatever the hell a fuel cooler is, don't change your EGT, unless they are curing knock, which they shouldn't be, unless you were overheating before you added them.
d) people spend a lot of money to put body kits on their car too. money doesn't make the car run better or your brain more knowledgable.
e) good FMIC will not bring down the temp of the engine. it will bring down the temp of the air going into the engine, which, under optimal conditions, will still be exhausting at the same temp. Do you think colder intake air makes the explosion in the cylinder colder?? If it did, it would be counter-productive, as less heat = less energy = less power.
(edited cause my b ) turned into a smiley )
Old 05-11-2004   #33
SlowWhite
SlowWhite's Avatar
Jason,
As you can tell most of us here are very spectical people. (we just deal with a lot of people who "think" they are in the "know" but really are clueless)
So with that said come out to Uni or to one of our events. - Bring the car and take someone or a spin. Cause that's the fastest and best way to back up what you say.
Sorry if we come off as Harsh it's just from what you're telling us, your car is the exception to just about everything that we've seen/proved ourselves. As you can hopefully tell this forum is full of some really knowledgable people, some who own Shops, work at shop, or have built/owned/tune there own cars to way above average HP numbers.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
