Old 05-03-2011   #21
Re: Bent valves? or Droped a valve, Pictures inside!
Originally Posted by 1999Gst View Post
okay cool i think i'm going to pull the head today or wensday, i'll post some pics. What should i do for a head gasket and studs? kinda off topic but i have a 16g and wanna run e85 and go around 350
stock head bolts and the factory organic gasket will do you just fine.
Old 05-03-2011   #22
Aren't new headbolts kinda pricey?
Old 05-03-2011   #23
I didn't think they were torque to yield bolts? I would reuse them on a mild setup.
Old 05-03-2011   #24
The 6 bolt head bolts are not TTY, so if the threads look good put some oil on the threads and under the bolt head and fallow the factory torque down method. Or a set of ARP head studs is around $100 new. If you go the ARP route I recommend torquing them to 100ft/lbs with the moly lube. And if you use a composite gasket to put copper spray on it.
Old 05-03-2011   #25
1999Gst
Drives: 1999 Eclipse,
Yea i had a 6 bolt lined up but that fell through, so a Yeai'm a go mls and get some arps and post some pics of my little rebuild in the project fourm.
