Old 05-27-2011   #21
Sparky2211
Sparky2211's Avatar
Drives: 2g DSM, 2008 Evo X
Re: Project 2G GSX
I'd skip the cam gears. If I remember correctly the HKS cams are designed to be installed straight up, maybe I'm wrong though.
If you can find a buyer for the EMS, I'd recommend ECMLink instead, it's a lot easier to tune and use.
Good luck with your project!
After talking with Shane, I think I am going to switch to ECMLink. I have a few questions though. What all do I need to run ECMLink versus AEM EMS? I'm guess I won't need my AEM AIT sensor anymore. Do I still need a 5-bar MAP or just get a 3-3.5" GM MAF? Trying to get everything together and ordered. I don't have the OEM ECU. Which one would I need to get?
1997 Eclipse GSX - Project car - 601hp/475tq
2008 Evo X GSR SSS - Daily Driver - 407hp/434tq
Sparky2211 is offline   Reply With Quote
Old 05-27-2011   #22
Re: Project 2G GSX
Why a GM MAF? Why not just stick with a Mitsu one? 2g and Evo 8 MAS's go a long way. I personally wouldn't run a GM MAF unless I had no other choice, not worth the hastle in my opinion.
Old 05-28-2011   #23
Re: Project 2G GSX
Or you could keep the IAT and MAP sensors and run speed density with ECMLink.
Old 05-28-2011   #24
Re: Project 2G GSX
x2. Keep the iat and map sensor and just run speed density with it. I know you used to always want a '95 eprom ecu for ECMLink. I'm not sure if you can use other years that aren't eproms any more though.
Old 05-28-2011   #25
Sparky2211
Sparky2211's Avatar
Re: Project 2G GSX
This is great news. I wasn't sure if that was an option with ECMLink. Makes me feel a little more comfortable that I would only need to give up the AEM EMS versus everything that I already have.
Old 05-28-2011   #26
Re: Project 2G GSX
And you'll be a couple hundred dollars ahead after selling the AEM and getting ECMLink.
Old 05-28-2011   #27
Sparky2211
Sparky2211's Avatar
Re: Project 2G GSX
Even better, then I can spend it elsewhere.
Old 05-31-2011   #28
Sparky2211
Sparky2211's Avatar
Re: Project 2G GSX
Added ECMLink to my list of parts to get. What should I run for injectors?
Old 05-31-2011   #29
Re: Project 2G GSX
Lots of people like the FIC 1680 high-Z injectors for E85. My FIC 1350's aren't bad, but a friend with a similar setup to mine has FIC 1450's and hates them.
Don't get PTE 1200's if you're running E85 either. There have been about a million of them to fail, some people say they are not compatible with E85, others have run them with no issues. I wouldn't take the chance on a vehicle of mine.
Old 05-31-2011   #30
Sparky2211
Sparky2211's Avatar
Re: Project 2G GSX
Cool, thanks for the info. Shane also recommended those injectors. Sounds like people have really liked them.
Old 06-15-2011   #31
Sparky2211
Sparky2211's Avatar
Re: Project 2G GSX
Updated my parts list. Getting a little closer to done.
Old 06-15-2011   #32
Re: Project 2G GSX
Very nice and long mod list! We need moar pictures!
AEM widebands have a very easy to read display and are easy to log in dsmlink.
Also depending on how much power you're looking to make a boost a pump is an easy option to make more power on a single pump and not do anything crazy.
Old 06-15-2011   #33
Sparky2211
Sparky2211's Avatar
Re: Project 2G GSX
Thanks Brad, I was thinking about going with the AEM wideband. As far as the fuel goes, I am not really sure on what kind of power I will be making. I'm guessing somewhere around 500 give or take some.
I'll post up some pictures soon! I really don't have many right now to be honest. lol
Old 08-27-2011   #34
Sparky2211
Sparky2211's Avatar
Re: Project 2G GSX
Just finally registered and insured the car last week. I am hoping to have it on the road within the next couple of weeks. Such a good feeling to finally get to this point! Now I am curious as to what kind of numbers I will pull.
Old 08-30-2011   #35
Revobasher
Revobasher's Avatar
Drives: 14 Evo X GSR
Re: Project 2G GSX
Winning!
Revobasher is offline   Reply With Quote
Old 02-18-2012   #36
Sparky2211
Sparky2211's Avatar
Re: Project 2G GSX
Well, the car has been done for about a month or two now. Here were the final build parts. The car is a complete blast to drive!
Block:
- 2.0L MAP 6-bolt
- Eagle Rods
- Ross Pistons
- MAP Ultimate H11 Headstuds
- Fel-Pro PermaTorqueMLS Head gasket
- Gates Timing Belt
- ACL Rod Bearings
- ACL Main Bearings
Head:
- 1G MAP Stage 3 Cylinder Head
- Ferrea Valve Guides
- Ferrea valve seals
- GSC Springs, Retainers, seats
- MAP +1mm Nitride Valves
- HKS 280 Cams
Fuel:
- FIC 1680cc BlueMAX High Impedence Injectors
- Walbro 400 Fuel pump
- Fuel Labs Fuel Pressure Regulator
- Turbosmart FPR Liquid Fill Gauge
- AEM Fuel Rail
- MAP Filter to rail kit
Intake/Exhaust/Turbo:
- ETS 10.5" Race Intercooler Kit
- PTE GT3561 turbo
- Magnus Race Intake Manifold
- DNP Turbo Manifold
- Apexi turbo-back
- Accufab F75 5.0L 75mm Throttle Body
- Tial 44mm Wastegate
- Tial Q Blow Off Valve
- MAP 44mm O2 Housing
- Hallman Boost Controller
- MAP 3" Intake/filter
Drivetrain:
- TRE rebuilt transmission
- Competition Clutch Stage 4
- ACT Lightweight Flywheel
- Prothane Motor Mount Inserts
- Techna-Fit Clutch Line
Electronics:
- AEM AIT Sensor
- AEM 5-Bar MAP
- Eprom ECU w/DSMLink V3
- GM 3" MAF Sensor
- Prosport Peak/Hold Boost Guage
- Prosport Peak/Hold Oil Pressure Gauge
- Innovate Wideband Guage
Suspension/Wheels:
- Koni 5-way adjustable shocks
- H&R race springs
- ADR 17x7 wheels
Misc:
- Mishimoto Aluminum Radiator
- Mishimoto 12” Electric Fan
- Taylor Battery Relocation kit
Filling up for the first time:
Engine bay mostly done:
Dyno:
Old 02-18-2012   #37
b00sted_spyder
Re: Project 2G GSX
Good to see another high HP 2g. Looking very good.
Old 02-19-2012   #38
Re: Project 2G GSX
I like the way it keeps making power with RPM.
Old 02-19-2012   #39
Re: Project 2G GSX
Nicely done. Can you link me to these High-Z 1680 injectors? I've never heard of them.
Old 02-19-2012   #40
Sparky2211
Sparky2211's Avatar
Re: Project 2G GSX
Sure, np.
http://www.maperformance.com/fic-168...226-1680h.html
