Old 08-03-2011   #21
way2fastalon
IS Broken :-/
way2fastalon's Avatar
Re: tranny will not go in 1 3 5
manually put the tranny in first with out the cables hooked up hook the cable up and see where your shifter is ... if the cable wont hook up or let you out its the bracket for wrong year you might need to bend it the way you need it and check reverse too that is the longest shift for the cables you could have gotten 1g cables possibly witch are different?
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 08-04-2011   #22
derrecks92talontsi
Drives: 92 talon awd
reverse works it is just 1. thanks man i will try that. Could it be the tranny that is junk
derrecks92talontsi is offline   Reply With Quote
Old 08-04-2011   #23
93gtpeater
Drives: cbr 1000rr repsol
Yeah tranny could be junk. Pull it out and have it inspected.
Old 08-04-2011   #24
derrecks92talontsi
will i dont want to pull it out i will just get a new one any other ideas that people have at all i am thinking that it is junk.
Old 08-06-2011   #25
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Interesting I have a similiar problem, except for mine is good 1-4 ha no reverse or 5 th. . .I'm almost positive you can only mount that bracket one way. . .when people say bend the bracket bend it how?
