Old 11-23-2011   #21
Mark Leasure
Mark Leasure's Avatar
Re: Mark's Evo IX MR Winter Projects
I'm sticking with low compression, works on my 1G. It’s going to be an identical lower end, except 6 bolt vs 7 bolt. I already have pistons for my build too. It becomes more important to build in detonation margin in the system since I’m using an AEM that lacks and suffers from the ability to react to knock like the factory ECU. The AEM has an insufficient level of knock control algorithms that the stock ECU has. Spool is important but I’m not willing to sell my soul, a good reliable 700WHP setup is what I’m trying to build.
Old 11-23-2011   #22
I can't wait to see this in action.
Old 12-03-2011   #23
Mark Leasure
This afternoon I milled up a fixture for my upcoming manifold fabrication project. I’m doing a top mount v-band manifold for a BB 6266. It bolts down the head flange to reduce warping when I finish weld everything together. I also included a port on each runner for back purging. I also built a jig to cut SS pipes at precise angles to fabricate a v-band merge collector.
Old 12-04-2011   #24
daneatsv8s
Drives: 91 Galant VR4, 97 Eclipse GSX, 91 Talon TSI
Nice work Mark.
daneatsv8s is offline   Reply With Quote
Old 12-04-2011   #25
http://www.solarflux.com/Pages/Productinfo.html
For SS welding I used this, its a powder you mix with methanol and put on the back side of each weld with a little brush. You mix it to a not to think, not to thin paste and after your parts are all mocked up I mark and break it all down to put the flux in.
It leaves a black glassy backing where the weld is, then wash out your pipes when you are done. Looking good, this should move out when your done.
Old 12-11-2011   #26
Mark Leasure
Quick update: I fab’d up my merge collector this weekend. I’m still waiting on the v-band to finish it up. I plan on assembling my engine next week. I’m still waiting for the transfer case to come back from jacks before I can get the engine back in the car. I have a couple of weeks off at the end of the month and I plan on wrapping up the motor/trans/t case installation, with a stretch goal of finishing my manifold fabrication then too!!
I bought one of those gas saver lenses and another argon regulator for back purging. I haven’t welded much stainless in the past so for a first try I think it turned out awesome.
Old 12-11-2011   #27
Not bad for a newb! :P
Very nice man.
Old 12-11-2011   #28
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Nice work Mark!
I'll have to find time to make my way over to your place and check out the work first hand.
I need some motivation!
Old 12-11-2011   #29
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Nice work Mark!
Very nice! Jim, pick me up on the way, i wanna see this cool shiat too
'04 Honda Ricer: stock
Old 12-12-2011   #30
I'd like to take seat no. 3
Old 12-13-2011   #31
Mark Leasure
Nice work Mark!
Just tell me when you want to stop over!
Old 12-14-2011   #32
Mark Leasure
I welded the v-band flange to the merge collector last night. V-bands are awesome; they align the turbo to the collector perfectly. I rough ported the collector, still needs refining.
Old 12-15-2011   #33
Me like.
Old 12-15-2011   #34
Inspiring, maybe i should quit watching cartoons and practice welding. (not that I can weld anywhere near as good as you)
Old 12-17-2011   #35
Mark Leasure
Good progress today, assembled the 2.3 motor today. MAP built up my head too, with Kiggley springs and retainers, new MAP SS valves with bronze guides. This thing is going to be fun!
Old 12-24-2011   #36
Mark Leasure
Just finished cleaning up the merge collector.
Then I modified the crank scraper & windage tray due to the stroked motor.
Old 12-24-2011   #37
What did you use to clean up the merge collector?
Do those motors come stock with a scraper and windage tray?
Old 12-24-2011   #38
Mark Leasure
A die grinder with a flapper wheel. I got the wheels at Northern Tools, 2.50 each. The scraper and windage tray come with the AMS oil pan kit.
Old 12-24-2011   #39
Damn things are really scootin' along Mark! Are you going to get the motor back in the car to mock up the rest of the turbo setup or what's the plan?
Old 12-24-2011   #40
Thanks, I'm trying trying to learn the ways and I appreciate it.
