Old 06-18-2014   #1
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
1g Partout!
1994 Eagle Talon TSI AWD - Full part out!
Sold items will be deleted from list.
Small stuff not listed I likely have so ask me!
If you want specific pictures of anything text me
I’m located in South Minneapolis……AJ 503-504-2809
Stock 4g63t longblock (w/ARP head studs, balance shaft elimination)
about 140k miles on it, virgin block and crank, low compression.
(Compression readings 135-90-135-135) - $300
All 4 poly motor/trans mounts
(pretty much brand new) - $100
Kosei 17" wheels with newer Bridgestone Potenza RE970AS tires (225/45/17). Wheels were spray painted black and could definitely use refinishing. - $300
Interstate MT-51 500CCA battery
(bought new 3 months ago) - $80
Nice tinted 1GB tail lights (high quality not night shades) - $40
1gb clear corner lights - $10
Injen intake pipe - $30
CAS green top - $20
Front Lower Control Arms, both sides, fresh bushings/ball joints
(have about 60 miles on these since new) - $60 for the pair or $30 each
FIC 1250cc fuel injectors - $300
New 1g turbo/manual stock FPR - $20
1g instrument cluster, shows 129,052 miles, has carbon overlay - $40
Stock 1g (turbo, manual trans) Eprom ECU - $60
1g non-cruise control throttle cable - $20
1g rear strut bar - $20
22 spline transfer case - $100
1g awd driveshaft - $60
1g awd fuel tank - $50
OEM clutch master (less than 1000 miles on it) - $50
OEM slave cylinder (less than 1000 miles on it) - $50
LSD 4-bolt rear diff w/axles
(complete rear subframe available) - OBO
Front AWD CV axles (and a few intermediate shafts) - $40 each
1g awd front dual piston calipers w/lines - $50 for the pair
