Old 06-21-2004   #21
ACRucrazy
Looks nice!
Wheres mine!?
Slow stuff
Old 06-22-2004   #23
SlowWhite
Been there, done that.
SlowWhite's Avatar
I boosted 20psi Daily on pump with the 20G.
I'm hoping this whole set will yeild more then 322whp on pump. Cause if it doesn't am seriously going to have a break down.
Things I've changed
Stock Intake Mani - 2G Mangus SMI
Stock 2G TB - 1G TB
HRC 2.25" long route I/C piping - 2.5" Short Route I/C piping
GReddy 24Row FMIC - GTR FMIC
RC550 - FIC 850's
CM Stg 3 - ACT 2600
SAFC - DSMLINK V2
OLD ARPS - NEW ARPS
I changed all that and actually Lost 1HP Between my GS-T(322whp on 92 oct) and my GSX (321whp) - and my power was dropping off at 6800rpms regardless of the fact I have HKS 264/272 and a SMI... which should have carried the power straight to redline. (8,000rpms)
And that's all I could muster out of my S20G on pump.
I've now upgraded again:
Turbonetic T3 manifold
PTE TO4S GT3561 .63A/R with 5 bolt T3 exhaust side
Tial 38mm Waiste Gate - routed back into exhaust
2.5" 02 housing
FP 4" Intake
New K&N Filter
Also wanted to add on the Pict 9 (Bling)
I'm having Jet Polish My compressor Cover and FP intake to match my VC and Magnus SMI.
I've also talked to MIke at QPR to fab me up a Sheet Metal heat sheild for my exhuast Manifold. Which I'm hoping will complimet my VC as well.
There are also plans for a Fluidyne Radiator. But not sure when that'll happen.
After the Mayhem Jenny and I want to go on vacation someplace. But not sure where/when yet. So I'll be saving for that trip first.
Anyrate thanks for the compliments. It's been a long haul but it's finally coming together.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
Old 06-22-2004   #24
Ack! I didn't know you were running the wastegate off of the #1 runner! You should let the person making up your parts know things like this!! Be careful running that thing off of the #1 cylinder. It can make it go lean compared to the others.
Old 06-22-2004   #25
SlowWhite
SlowWhite's Avatar
Sorry I thought you knew?
I wanted a Cast manifold, vs Tubular. And this was what was available.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 06-22-2004   #26
You are supposed to put a block off plate over that wastegate mount and put it on the O2 housing where it belongs!
Old 06-22-2004   #27
SlowWhite
SlowWhite's Avatar
I can do what ever you want. But you're the one fabing up the 02 housing.
I originally had to do it off the Manifold because of the 4 bolt exhuaust housing I was going to go with. But now that I have a 5 bolt with a Hole. I can run it off the 02 housing if that's how you want to make the 02 housing?
I'm down for what ever as long as it works.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 06-22-2004   #28
Bah, it doesn't belong on the O2 housing. You can't even do that at all with a T4 exhaust housing or the 4-bolt outlet T3 exhaust housings.
Old 06-22-2004   #29
SlowWhite
SlowWhite's Avatar
I know Lacroix, and Moe both are doing it the way I have it.
So I should be ok.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 06-22-2004   #30
Manifold mounting is the way to go. My waist gate has a 18psi spring and with no boost controller it starts at 16 and creeps to 18 by redline.
Old 06-22-2004   #31
Blade
Guest
Tournaments Won: 6
Posts: n/a
Looking Real nice. Great work Brian! :thumbsup:
Old 06-23-2004   #32
If not done on the O2, it should be put in the collector. Lets start something in basic tech if this goes any farther.
Brian should have the O2 housing back and done on Thurs. Get that beast running by this weekend!
Old 06-23-2004   #33
SlowWhite
SlowWhite's Avatar
I have to have it running by Thursday Night. (I have Dyno time schedualed for Friday after I get off Work)
Won't be the prettiest thing to look at but at least it'll be running. I can't find my paint gun so I'm now stuck with prepped Front End that looks like ARSE.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 06-23-2004   #34
Hey what kind of turbo is that exactly? Curious how big it is.
Old 06-23-2004   #35
SlowWhite
SlowWhite's Avatar
Slightly larger then the Standard SCM 61
Larger compressor cover, bigger exhaust wheel, T3 housing.
Shane knows the spects better then I do.
But basically it's a non ball bearing version of FP's 3565 (ie: larger brother to there 3065) but built by PTE.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 06-23-2004   #36
illz
Originally posted by JET+Jun 23 2004, 06:40 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (JET @ Jun 23 2004, 06:40 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-ecoli@Jun 22 2004, 08:51 AM
Bah, it doesn't belong on the O2 housing.&nbsp; You can't even do that at all with a T4 exhaust housing or the 4-bolt outlet T3 exhaust housings.
Brian should have the O2 housing back and done on Thurs. Get that beast running by this weekend! [/b][/quote]
why do you think it would run lean on #1 if the wastegate is on the #1 runner?
Old 06-23-2004   #37
See thread in basic tech.
Old 06-24-2004   #38
SlowWhite
SlowWhite's Avatar
Well Car won't be up for another 1 or 2. My 02 housing didn't even come close to working.
So I'm just going to have a full 3" 02 eliminator or something built instead.
Actually I'm not to upset. It gives me another 2 weeks to work on the car and getting it looking better, etc.
Yesterday I descided to Wash it for the first time in 6 months. (all I have to say is DAMN that was a lot of dust)
I found some left over PPG Paint (OEM White for my car) now if I can just find my damn paint gun I'll be good to go.
-Brian
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
