Old 07-07-2004   #21
b00stingsx
Send a message via AIM to b00stingsx
There are 4 marks on the timing cover, which one is zero though? There is a 10 mark but thats it. The other 3 marks arent numbered.
b00stingsx is offline   Reply With Quote
Old 07-07-2004   #22
joem
Drives: 1991 Talon awd auto
the other side of 10. 10---?---?---0
joe
Old 07-07-2004   #23
It is marked, for 15, 10, 5 and 0 TDC. clean off the plastic it probalby has dirt and what not all over it. Also were do you live I could come check it out after work tonight.
(763) 550-2962 I work 1pm-9pm.
Old 07-07-2004   #24
b00stingsx
im in edina, tonight isnt good for me though. im gonna go check it to see if it lines up to the zero. I dont think it does...
Old 07-07-2004   #25
b00stingsx
it did jump a tooth, is there a way to see if the valves are all bent? or are they bent for sure?
Old 07-07-2004   #26
joem
If it jumped less than two tour good replace the belt water pump and tenc. and be done.
joe
Old 07-07-2004   #27
joe
Engrish man, Engrish!!
If it just jumped one tooth you should be ok. If it jumped 2 teeth, then you may have problems. Over 2 teeth and you are almost definately in trouble. Check out the VFAQ's for items to buy.
Old 07-07-2004   #28
Raptor
ConArtist
Raptor's Avatar
If you need me to I can come check it out with the boroscope to make sure there isn't valve to piston damage. Call the shop if you want more info. QPR that is.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 07-08-2004   #29
b00stingsx
ok, how dirty is is supposed to be inside the timing belt cover. its reallly greasy and dirty? Can I just get a timing belt from checker or should I go to mitsu? How about a waterpump? just wondering because i get a deal through csk proshop, making things alot cheaper.
also, what is the procedure to line up all the timing marks since my belt jumped a tooth?
Old 07-08-2004   #30
I would buy the parts through Mitsu. You may as well replace the water pump and maybe the tensioner while you are in there. How long has it been since your car has had a t-belt job? You might as well replace teh b-shaft belt or remove it.
As far as the oil and grease, you may need a seal on the front of your engine. Feel the seals on the front case and see if they are like plastic or rubber.
