Old 08-12-2004   #21
With the Eagle rods, did the ends require any resizing before use?
Old 08-12-2004   #22
Since we were capping at 46lbs a min, and chris talked to a dsmlink guy that looked at his log and 'estimated' at 51lbs/min I would venture a guess of 450-475awhp right now.
And the problem was the wires, not the plugs.
When he gets back, he'll throw in a maf-t and up it to 35psi or so on elites dyno.
Old 08-12-2004   #23
SlowWhite
Been there, done that.
SlowWhite's Avatar
I was reading that also on dsmlink forums. (I'm the one that asked the question)
51lbs/min is impressive considering:
1G head
1G Cams
1G Intake Manifold
I'm seeing 52lbs/min on pump gas with my car. But I'm reving to 8,000rpms how high is Chris Reving his car to? and it's creeps from 22psi at 7200rpms up to 25psi when I hit 8,000rpms.
On Race Gas at 25psi - I was seeing 54lbs/min for my 456.7whp?
And I'm running HKS 264/272s, and Magnus SMI.
So gets some damn cams, and a sheet metal in that thing and let see some 57lbs/min
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
Old 08-12-2004   #24
I dunno, it was an estimate via my butt after riding in johns car. We are only running 25.3psi peak, its averaging around 23psi I would say. Spool-up is insanly fast and he is reving to 7500rpm right now. Once he does some head work/sheetmetal/cams this winter, it should really scoot!
On the dyno we were hitting 36lbs a minute or so. It would get to 42, then fall back, then go back to 40 and make peak power. I'll see if I can get some dyno graphs posted sometime soon. The car was missing the entire time, and still made good power.
I wish we would of swapped plug wires at the dyno, would of saved time last night, but things always work out for the best. If the car would of been 'tuned' not last night, drain plug would of probably fell out somewhere in Wisconsin and he would of been SOL. Sometimes things happen for reasons..
Old 08-12-2004   #25
Enes
Enes's Avatar
so true..
congrats...
and btw, Chris, you called? sorry i missed your call. whats up?
_E
Old 08-12-2004   #26
Probably thought he needed a tow... LOL
Old 08-12-2004   #27
SlowWhite
SlowWhite's Avatar
I don't know about his car.
But we are basically running the same turbo but he has a .82 a/r
And I know the difference in Airflow from 7500 - 8,000 is big.
At about 7500rpms - most of the time I'm only at about 45lbs/min
At 8,000rpms I'm at about 52lbs/min
So all I got to say is DAMN - maybe he will hit 60lbs/min with Cams, And SMI.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 08-12-2004   #28
Enes
Enes's Avatar
it must be something about that 7th bolt thing that is causing the problems with the transfer case!
-E
Old 08-12-2004   #29
-E
its all in the QPR Inc 2.4 .
Old 08-12-2004   #30
Raptor
ConArtist
Raptor's Avatar
[EVILMENIACLEVOICE]No one will ever know because it's top secret I do my work early in the morning when all you girls are asleep for just that reason Muhahahaha.[/EVILMENICLEVOICE]
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 08-12-2004   #31
*Cough Cough*
Old 08-12-2004   #32
to the pistons? no, not in Chris's case. 1G rods to 2G pistons or 1G rods to Wiesco's are in need of some machining/bushing.
Old 08-12-2004   #33
Raptor
ConArtist
Raptor's Avatar
Ross pistons also can require pin fitting to the rod on the small end. Wisecos are usually dead on.
651-488-7774
Old 08-12-2004   #34
I'm referring to the build quality of the Eagle rods. There have been people who have run into trouble with the Eagle 4G63 rods having imperfections which required possibly resizing them, as in the journals not being in spec from the factory.
Old 08-12-2004   #35
illz
no prob with mine
Old 08-12-2004   #36
v8klla
v8klla's Avatar
Nope no problems with the rods, and Mike checked everything over himself 7 or so times to make sure lol!
Yeah with the MAS pinned I am not sure about actual airflow, basically the ECU is guessing at this point based on VE tables...Also revving the 8000 at this point is doable, but probably wouldn't yield much of a gain due to stock head/cams/intake manifold...
We'll stick with 7500 and 25 psi for the SO, once I get back we'll see whats up
Chris
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 08-13-2004   #37
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Chris, looks like you are heading in the right direction. Nice job on the 7bolt, hope you do well at the SO.
Does everybody have 400+ HP cars now? :bounce:
Jim
Old 08-13-2004   #38
no, yours hasn't started yet. lol
Old 08-14-2004   #39
I believe Chris has a larger turbo than you Brian if I can remember right. You have a gt35 right?
Old 08-14-2004   #40
400hp out of a 16g? I can sure as hell try! :woowoo:
