Old 12-23-2004   #21
LightningGSX
Hellbound
Re: Any body using tmo chips?
They are refering to non-eprom ECUs.You do have an eprom ECU right?
-Nulli Secundus-
Old 12-23-2004   #22
dsm10sec
dsm10sec's Avatar
Send a message via AIM to dsm10sec
Nope, guess I should buy one, huh? But, if I get one what's the point of you socketing it, isn't it already socketed?
dsm10sec is offline   Reply With Quote
Old 12-23-2004   #23
LightningGSX
Hellbound
Nope, unless you buy one that someone has already socketed
-Nulli Secundus-
Old 12-23-2004   #24
dsm10sec
dsm10sec's Avatar
Oh, maybe I should just get an AEM EMS witha wideband then.
Old 12-24-2004   #25
LightningGSX
Hellbound
Slight difference in price, like maybe $1400-$1500.
-Nulli Secundus-
Old 12-24-2004   #26
wow, I guess I didn't realise how easy it was to program these. So you're saying someone like myself that has no clue on burning these chips would be able to do this no problem? Just gotta come up with all the numbers myself, and it burns it easy as cake? Maybe it's worth me screwin around with.
Old 12-24-2004   #27
LightningGSX
Hellbound
Yep pretty much.Evilscribe, at present, will handle fuel/timing maps, rev limiter, injector comp, idle speed, MAF swaps(2g into 1g, etc), and fuel cut.If you want to add stutter routines, alter stock boost gauge, etc you will need some experience.I'm sure in time, this will be added to Evilscribe as well.
-Nulli Secundus-
Old 12-24-2004   #28
LightningGSX
Hellbound
I should add, all this is for 1G's only.
-Nulli Secundus-
Old 12-24-2004   #29
It's worth it until you screw up and damage your engine.
Old 12-24-2004   #30
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Ehh, it's working fine for me. Normally, if you screw up the car won't start. Until I got it figured out I burnt a whole bunch of chips and ended up erasing them because of various mistakes I made. If anybody buys one of the programmers off ebay (like I did) I can help you figure it out. The hardest part is that they don't come with instructions really. The burner also works off laptops, so if you have a laptop and a few spare chips, it's possible to tune your car at the track.
As far as "blowing up the car", if you manage to blow it up with this, you would have blown it up with any other tuning system.
Old 12-24-2004   #31
LightningGSX
Hellbound
Really, theres a few very minor things that can give you big problems, but they're simple to overcome, and like Ryan said, the most that will happen is your car won't start.Of course you can enter bonehead values in your fuel/timing maps, but its the same with any other tuning device.So if you can't figure this stuff out after a few tries, you have no business doing anything to your car, other than driving it.
-Nulli Secundus-
Old 12-24-2004   #32
LightningGSX
Hellbound
Since we have whored up this persons thread, maybe the mods could seperate this suff into another thread and Ryan and I could add instructions.
-Nulli Secundus-
Old 12-24-2004   #34
LightningGSX
Hellbound
Originally Posted by dsm95gsxer
I have a 2g eprom is it similar?
Nope
-Nulli Secundus-
Old 12-24-2004   #36
LightningGSX
Hellbound
What is the difference?
Different processor, instruction set, eprom, hardware registers and code.
-Nulli Secundus-
Old 12-25-2004   #37
Done.
http://www.dsmstyle.com/forums/showthread.php?t=5948
