Old 01-15-2005   #21
DSM1G
DSM1G's Avatar
Drives: 1993 talon tsi, 2003 dodge ram
Send a message via AIM to DSM1G
Re: Dead 1g
This same thing happened to me on my old engine. A piston came up and bent some valves. It didnt know what it was because it would still sound like it was trying to start but it wouldnt. It sucked, thats about all I have to say.
DSM1G is offline   Reply With Quote
Old 01-15-2005   #22
nathan
Guest
Tournaments Won: 6
Posts: n/a
Re: Dead 1g
Yeah I say you have major timing belt issues.It does not take much to warp or bend a valve.Trust me thats why my car is down right now.
Old 01-15-2005   #23
emiz
Re: Dead 1g
ahh.. i guess its time for a rebuild .
emiz is offline   Reply With Quote
Old 01-15-2005   #24
520Talon
Re: Dead 1g
I had the same thing happen when I had a balance shaft sieze. Shaft and timing gears didn't move but the rest still turned with the starter. There was no teeth around the crank. What teeth should have been there where taking the place of the balance shaft belt that was elsewhere in the timing belt cover. I just got a whole new motor.
Old 01-17-2005   #25
Raptor
ConArtist
Raptor's Avatar
Re: Dead 1g
The other possibility is the crank key that keeps the timing gear in proper index sheared or came out. I have seen that happen as well and it will cause exactly what you are experiencing. Likely as mentioned, you have a whole heard of bent valves, you can pull the cams quick and see if they all return to closed position to check quick, but it doesn't sound good.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
