Old 02-06-2005   #21
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Re: What is everyone's opinion on lightweight flywheels?
I know my ACT was stepped correctly out of the box, I can't say for Fidanza though.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 02-06-2005   #22
The Fidanza is stepped correctly also.
Old 02-07-2005   #23
So how long does the friction surface last on a fidanza? Average wear are we talking less than 25k? I know it depends on how you use it but lets say it came on the car stock?
Also same for the ACT? Anyone have advice for me on what I should do if I have to replace my clutch in a month or so when pull her out of storage? It would be nice to have a lightened flywheel and from the reviews Im torn between the ACT and fidanza, but it will be a daily driver so parking and such needs to be taken into acount. Thats wear Im torn. The Fidanza is so light I guess parking or rolling very slow sucks, but the ACT is quite a bit heavier.
Im just wondering why go light if your not going to go all the way? Im guessing drivability and launch issues.
Old 02-07-2005   #24
It isn't like the Fidanza is a whore or anything, I daily drove mine with one for years. I would probably go ACT if I wasn't putting a lot of power down though.
Old 02-08-2005   #25
Regarding the stalling and idle problems when letting the clutch out. Wouldnt removing the ISC and FIAV with a blockoff plate eliminate the ECU's control on the idle and keep the engine speed wherever you set it with the BISS? Even when coming to a stop or letting of a high rev?
I would think that would be a solution.
Old 02-08-2005   #26
Sean485
Guest
Tournaments Won: 6
Posts: n/a
No because the ecu shuts off fuel above a certain rpm when you let off the throttle completly and with the light flywheel it comes down faster than the ecu anticipates and stalls before the ecu starts firing the injectors again.
Old 02-08-2005   #27
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Originally Posted by ecoli
It would even less cool to have a stock flywheel come apart at 9000RPMs and come through your hood.
The reason I also have a scattersheild.
EDIT: This is Carlos under James' name.
7/25/09
Old 02-08-2005   #28
Not 100% acurrate, but close. The injectors fire again before the car stalls, just not soon enough to catch it. You can raise the rpm and fuel cut limits in DSMLink to help. The thing I noticed also is that the ISC does not come back up enough to catch the engine either. Using the FIAV/ISC block-off would help keep the correct amount of air going into the engine so once fuel is back the engine would not stall as easilly.
