Old 03-04-2005   #21
chengsta
chengsta's Avatar
Drives: '93 mirage es - evoIII
Re: SSQV BOV help
Put what little filter in line, JET? but anyways I did a boost leak test today and everything is fine, no leaks to be found. Anyone have any other ideas what could cause the problem?
chengsta is offline   Reply With Quote
Old 03-08-2005   #22
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Re: SSQV BOV help
Swifty, please make a new thread. There are also a couple of threads that have already talked about this. Do a search for SSQV. I don't want this thread to get too far off topic. Thanks!
Old 03-08-2005   #23
Re: SSQV BOV help
There is a little black round thing with a nipple on each end. This is a filter/buffer that should to inline to the SSQV. It helps to buffer any pressure waves going to the BOV and keep it from falsely going off.
If don't have those lines all clamped/zip tied tight, they are going to blow open and pop your BOV. Did you ever do that?
Old 03-09-2005   #24
chengsta
chengsta's Avatar
Re: SSQV BOV help
Thanks for all the replies. I finally got my SSQV working properly and pushing 15psi with no poblems now.
Old 03-09-2005   #25
Re: SSQV BOV help
What was the problem?
Old 03-09-2005   #26
chengsta
chengsta's Avatar
Re: SSQV BOV help
Not really sure but I believed it had to do with my MBC being stuck closed. But after testing for boost leak i disconnected and reconnected the MBC, re-zip tied all the lines and tighten the clamps and *poof* problem solved :P. I know that sounds weird but I'm just glad I solved the problem hehe.
